“Toyota red seal mechanic” says no metal in oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by winnipegbeachtacoma90, Jun 11, 2024.
  1. Jun 11, 2024 at 7:03 AM
    winnipegbeachtacoma90 [OP] Konto wird nicht mehr verwendet
    Error:
  2. Jun 11, 2024 at 7:06 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Does the napkin sparkle in the sunlight?
    Is it magnetic?
    What reason would you think that it's shaving itself?
    Stevie17 and Chew like this.
  3. Jun 11, 2024 at 7:07 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I'm no scientist but it looks normal to me.
  4. Jun 11, 2024 at 7:07 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Your current evidence is probably going to be a hard sell. I think Blackstone is the oil testing company you seek. Good luck.
    musicisevil, Stevie17, Chew and 3 others like this.
  5. Jun 11, 2024 at 7:07 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    If that's off the dip stick then it's likely just the dip stick scraping the guide tube mine is notorious for that gave me a heart attack the first time I saw it.
    soundman98, Stevie17 and Blak Shinobi like this.
  6. Jun 11, 2024 at 7:09 AM
    That’s good to know then, I think I’ll still get it tested but warranty is running out and I guess I’m just getting paranoid lol
  7. Jun 11, 2024 at 7:09 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    This. They don't care about what you 'think'. You need data if you want to argue about it.
  8. Jun 11, 2024 at 7:11 AM
    I’ll look them up, thanks! I’m out to gather more evidence and also just reassure myself everything’s good
    dryheat likes this.
  9. Jun 11, 2024 at 7:11 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you're worried about metal look in the filter
    seang likes this.
  10. Jun 11, 2024 at 7:27 AM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    As mentioned, the stick can be deceiving. Check your filter and the oil out of the pan itself. Wouldn’t hurt to invest in a magnetic drain plug as well. I also personally would not go with 10k OCI’s as fuel dilution will totally destroy the anti-wear additives in the oil and your wear numbers will go up.
    Barsoom likes this.
  11. Jun 11, 2024 at 7:30 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    https://www.blackstone-labs.com/
    Blackstone labs. I know several motorcycle riders that use them, one being a Navy pilot who told me the US Navy uses them.
  12. Jun 11, 2024 at 7:32 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Dealers are not owned by toyota, they just sell toyota.
    If the dealer finds a warranty issue, they will absolutely do the work as they get paid by toyota. But if they see something thats not going to pass through warranty, they wont do it as toyota can kick it back to them and then they have to pay for it.
    I worked as a warranty admin for a VW dealer, we absolutely loved fighting with VW to get stupid things covered under warranty. But you have to pick your battles with the manufacturer.
  13. Jun 11, 2024 at 7:32 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Warranty doesn't work that way.
    You can't just try to look for something that might seem off and just request it to get replaced, especially if it's about to end.
    First new car I take it?
    BillF1564, Stevie17, Chew and 3 others like this.
  14. Jun 11, 2024 at 8:20 AM
    Nope, always do oil changes every 5,000 miles, front diff every 10, transfer and rear every 15, transmission flushed every 25 so far everything’s great I don’t even have the transmission issues everyone talks about, but the oil concerned me slightly I’ll send it in for testing just to be sure.
  15. Jun 11, 2024 at 8:21 AM
    Thanks for the link, I’ll order a kit now
  16. Jun 11, 2024 at 8:22 AM
    You bet! Always bought used, ran high mileage and dumped it in a year or two, this is my first new “keep it forever” truck
    dryheat likes this.
  17. Jun 11, 2024 at 8:24 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    ATF every 25k is a total waste of time and money
    Your biggest concern having a 2GR-FKS should be to keep an eye out for one of the 10000 common leaks known to this engine.
    BillF1564 likes this.
  18. Jun 11, 2024 at 8:27 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You're already at 60K miles on a 2023? Not unheard of, but surprising.
    And as said above, warranty is not for the owner to pick out things that seem weird and then do a bunch of invasive work for free because of it. Warranty fixes a problem when a true problem arises. Be it noise, function, etc. Also as said above, check the filter, not the dipstick.
    Chew, RotorRPM and Wulf like this.
  19. Jun 11, 2024 at 8:35 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Test for peace of mind, but maybe Tundra’s recent drama has everyone seeing metal shavings everywhere we look these days.
  20. Jun 11, 2024 at 8:39 AM
    lavrishevo
    2023 Trail Edition
    I don’t agree with you on ATF. It’s for good reason that Aisin and many manufacturers recommend this type of interval. Aisin makes some of the best transmissions out there for longevity, and even without a filter, the key longevity is regular fluid exchanges. It should be a red flag that Toyota says one thing, but the actual manufacturer says something else…
