“VOLVO MAF” conversion 1997 to 1998 3.4, supercharger upgrade,
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Apr 4, 2018.
FOR THOSE THAT DID THIS SWAP, ARE YOU HAPPY WITH THIS MAF SWAP?
  1. Not happy and switched back to OEM bullet MAF
    27.3%
  2. Happy with swap?
    63.6%
  3. Got better gas mileage?
    72.7%
  4. Has better throttle response?
    63.6%
Multiple votes are allowed.
  1. Nov 11, 2022 at 10:48 PM
    #321
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Hmm. Almost forgot about this.. hood thing I’ve got a spare 01 MAF. My 1998 would like this easy mod lol
    1997tacomav6[OP] likes this.
  2. Nov 12, 2022 at 8:23 AM
    #322
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    Haltech has eliminated the use of the MAF for me, yeah
  3. Nov 12, 2022 at 10:12 AM
    #323
    Empty_Lord
    Dan
    Even with the Haltech I’d run MAF just because that’s how we deal with them on the 3.5l tunes. MAF curves are soo much easier for me to mess with than MAP. If I go Haltech I’ll run a modern maf though. Even smaller a
  4. Oct 28, 2023 at 5:12 PM
    #324
    Akl406
    Akl406 Well-Known Member
    Montana
    97 Toyota Tacoma Black 3.4 V6 5VZE MT
    I have read though this entire thread and the one this thread branched off of and I cannot figure out what to do haha. I have a 97 Tacoma with the old bullet style MAF. My current airbox is cracked in 2 different spots and I am going to replace it. 99-04 air boxes are easy to find not so much the 95-98. I know most people that have done this mod had super chargers. I do not have a super charger. I am wondering if my ecu will be fine if I switched to a 99-04 airbox and MAF sensor or if I need to stick to the original style airbox and do the Volvo MAF tube upgrade?
  5. Oct 28, 2023 at 6:07 PM
    #325
    1997tacomav6
    Denver
    Does not matter if it’s supercharged or not for the 97, should work
  6. Oct 28, 2023 at 7:29 PM
    #326
    Akl406
    Montana
    Doing either option?
  7. Oct 28, 2023 at 7:34 PM
    #327
    1997tacomav6
    Denver
    No, if you keep the 97 ECU and do the Volvo swap.
    A newer ECU will probably need a different wiring harness which would be a pain
  8. Oct 28, 2023 at 7:42 PM
    #328
    Akl406
    Montana
    I wasn’t planning on swapping the ecu my airbox is broken and was going to either put in a 99-04 airbox with updated MAF or try and source a hard to find 96-98 airbox and do the Volvo swap. I just don’t know what would be better
  9. Oct 28, 2023 at 7:47 PM
    #329
    1997tacomav6
    Denver
    Ohhh ok, the only issue is that the tube section has to be the same because the air flow rate has to be the same.
    you can’t put let’s say a 4” tube section across the MAF section because the air flow rate would be all messed up with more air but the computer thinks is lesser amount of air.
    if the tube section is the same inside diameter across the MAF section you can, if not you can’t
  10. Oct 29, 2023 at 9:14 AM
    #330
    Akl406
    Montana
    Yeah I am aware of the diameters and and getting correct AFR’s, I just couldn’t find a solid answer to if the 99-04 airbox with MAF would work correctly on a 97 :/. I know the Volvo will work with the 96-98 airbox you are proof of that!
  11. Oct 29, 2023 at 12:37 PM
    #331
    1997tacomav6
    Denver
    If the inside diameter on the 97 where the MAF is the same as the 99-04 airbox I would say yes, if not it’s a gamble but probably not IMO
  12. Dec 19, 2023 at 7:38 AM
    #332
    bloodyxsocks
    bloodyxsocks Well-Known Member
    1995.5 Toyota Tacoma 4wd
    Okay so I know this was a while ago but maybe you can help me. I have a 95 tacoma with the 5vzfe. The mass air flow sensor can’t be removed itself. I found a 1997 tacoma at my local junk yard. Would that one work? I looked at a video on your tube how to clean it on a 1990s 4Runner and the mechanic took out the sensor from the air box I believe. I found a 1996 4 runner at my local junk yard as well. Had 400k miles
  13. Dec 19, 2023 at 1:48 PM
    #333
    1997tacomav6
    Denver
    95-97 I’m pretty sure are the same MAF if you stay with the stock setup
    I think you can buy a complete aftermarket MAF with housing too
  14. May 2, 2024 at 1:06 PM
    #334
    flealr
    flealr Member
    Read quite some of the thread, but it was just too much. Sorry about that.
    Was there any definite conclusions for a 1996 truck?
    I believe it was made 10/95.
  15. May 2, 2024 at 1:43 PM
    #335
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
  16. Jun 4, 2024 at 5:51 PM
    #336
    flealr
    flealr Member
    Did mine as futureproofing, seems to work as good as before, I don't notice it's better. Couple weeks/gas tanks already done, no CEL. I don't think it will light up, pretty sure it would have already.
    My MAF readings went lower at same engine conditions which caused my long term fuel trims to go from negative to positive overall.
    MAF readings at IDLE no A/C, went from 3.62-3.66gr/s @ 698-713rpm to 3.05-3.06 gr/s @ 692-706rpm.
    I had around -10% LTFT at idle which turned to around +8% LTFT at the same condition. This 18% increase correlates to the 16% lower MAF reading.
    Reasoning is; having a larger MAF duct, intake air velocity is lower for the same volumetric flow, which causes the MAF reading to be lower and the computer believing less air is flowing, though the same air is flowing. After combustion, O2 sensors meter a lean mixture at this new operating condition and computer compensates by incrementing LTFT.
    I was expecting this before the install.
    I did not have any engine issues before or after.
    MAF installed is a new DENSO on a Volvo S60 5cyl 2.4L non-turbo body.
    My compression is on the low side which I believe causes the initial negative LTFT.
    Proper OEM NGK dual electrode spark plugs.
    Almost new DENSO O2 sensors.
    1996 Tacoma 3.4L SR5 4x4 Manual 270,000 miles.
    Hope this helps someone.
