“Will it fit” calculator
Discussion in 'Wheels & Tires' started by czukie, Sep 18, 2023.
  1. Sep 18, 2023 at 7:46 AM
    czukie
    czukie [OP] Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    Has anyone made a “will it fit” calculator? Seems like there has to be some sort of algorithm that can calculate if a wheel/tire combo will rub depending on tire size, lift height, offset, backspacing, etc.
  2. Sep 18, 2023 at 7:48 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    It's called the make it fit calculator :sawzall: Just messing with ya. But it all comes down to how bad do you want/need a certain size :cheers: A calculator/chart of some sort could be helpful.
