“Wub wub wub” sound/feeling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skee, Jan 19, 2025.
  1. Jan 27, 2025 at 1:42 PM
    skee
    skee [OP] Well-Known Member
    North Coast, CA
    2006 Tacoma TRD 4x4 Access Cab
  2. Jan 28, 2025 at 8:17 AM
    skee
    North Coast, CA
    Any ideas? ^
  3. Jan 28, 2025 at 9:19 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    did you do the wheel bearing test?
    put the wheel back on, only lift that side of the truck, grab the wheel at 12/6 (like on a clock) and push/pull. If you have play, its probably the wheel bearing, but could also be ball joints.
    There will be some play in the CV. The test for the needle bearing is if you put in 4H does the noise/vibration go away around 45mph?
    skee[QUOTED][OP] likes this.
  4. Jan 28, 2025 at 9:35 AM
    skee
    North Coast, CA
    Tested for play in the wheel bearing and it was still tight, LCAs/BJs were done about 2000 miles ago. I’m just wondering if that up and down play where the CV axle goes into the front diff. I’ve never really inspected that area before and it seems loose but maybe it’s normal? Truck is not lifted either so that’s why I’m hoping it not the needle bearing, and it still does the wub wub feeling in 4x4.
  5. May 20, 2025 at 11:50 AM
    Sabbathu
    Sabbathu Well-Known Member
    SoCal
    2019 Toyota Tacoma TRD Sport 4x4
    OP, did you ever figure out what the sound was? I have a very similar sound going on.
  6. May 20, 2025 at 3:45 PM
    skee
    North Coast, CA
    I never did. I changed both front wheel bearings, all u joints and carrier bearing, had tires rotated and balanced, with no improvement. I gave up and at this point am betting it’s one of my tires like some others suggested.
