⚠ Changed timing belt and coolant. This is what it sounds like.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Aug 28, 2022.
  1. Aug 28, 2022 at 3:52 PM
    Aircates
    Aircates Well-Known Member
    Texas
    1997 Tacoma lowboy
    Since both cams are out the same amount, the most likely cause was the crank was in the wrong position.
    Superdave1.0 and 5efvz[OP] like this.
  2. Aug 28, 2022 at 3:53 PM
    5efvz
    5efvz [OP] Well-Known Member
    Yup. I lined it up like that.
  3. Aug 28, 2022 at 3:54 PM
    5efvz
    I made sure to not move the cams or the crank when installing. Old belt came off and the new one went on.
  4. Aug 28, 2022 at 3:55 PM
    5efvz
    I will take more stuff off tomorrow to make sure that that is the case.
  5. Aug 28, 2022 at 3:57 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    Either way, it’s no harm no foul. Just have to line it up again. I always pull them through two full crank rotations in direction of rotation and then back to make sure nothing slips.
    Dm93, Superdave1.0 and 5efvz[OP] like this.
  6. Aug 28, 2022 at 3:58 PM
    5efvz
    Cool. I'm glad this engine doesn't have piston and valve in the same place.
  7. Aug 28, 2022 at 4:01 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    Most of our timing belt engines were non-interference. The VVt-i 4.7 and the 3.3 could bend a valve if their belt broke.
  8. Aug 28, 2022 at 4:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  9. Aug 28, 2022 at 4:49 PM
    5efvz
    Since everything is out of line now, can I just set the cams and the crank to TDC individually (i.e. without a belt connecting them all together)?
  10. Aug 28, 2022 at 4:51 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Set the crank to #1 TDC before pulling the belt. If you don't know how to, then research how to.
    Chungas likes this.
  11. Aug 28, 2022 at 4:51 PM
    Chungas
    Chungas Help! My Ferret has lost its stank!
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    Please don't take this the wrong way, what "stuff" besides the old, unpinned tensioner did you leave on? A timing belt job can be a pain in the ass when done correctly. I'm still trying to wrap my head around how you got the belt on with the tensioner still tensioning. Even with the marks not lining up. Pry bar?
    I just saw you left the lower cover on. Anything else?
  12. Aug 28, 2022 at 5:18 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    Yes you can. Pull your crank to the 0 mark and set the cams.
    5efvz[OP], Superdave1.0 and Chungas like this.
  13. Aug 28, 2022 at 5:22 PM
    TnShooter
    Deogee
    STOCK
    Probably the same way a lot of people do belts.
    They leave the belt OFF one of the pulleys and pull the shit out of the belt, which compresses the the tensioner, but plays hell on all the other components the belt goes around. And is NOT the correct way to do it.
    I’m not saying OP did it this way, but there’s ways of doing it.
    5efvz[OP] and Chungas[QUOTED] like this.
  14. Aug 28, 2022 at 5:31 PM
    Superdave1.0
    SoCal
    5efvz[OP] and TnShooter[QUOTED] like this.
  15. Aug 28, 2022 at 5:37 PM
    #35
    Chungas
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    5efvz[OP], Superdave1.0 and TnShooter like this.
  16. Aug 28, 2022 at 5:43 PM
    #36
    Superdave1.0
    SoCal
    Timing belt jobs seem doable. But they can go sideways when you don't know exactly what you are doing. Best to follow the factory service manual to the T.
    Done over a dozen timing belt jobs. 5vz, 2uz, 3.3 3mz, Honda 4 banger, Honda V6.
  17. Aug 28, 2022 at 5:52 PM
    #37
    5efvz
    I took everything off when I did the actual belt change. When I got the pics (as post #2 asked) I only pulled off the top plastic cover. When I correct the timing again with a new tensioner, I will take everything off (fan clutch, plastic covers, tensioner)
  18. Aug 28, 2022 at 5:53 PM
    #38
    Superdave1.0
    SoCal
    Another suggestion. Stop making new threads for each problem regarding this timing belt job. Keep everything in 1 thread so we all know the whole story.
    5efvz[QUOTED][OP] and TnShooter like this.
  19. Aug 28, 2022 at 5:54 PM
    #39
    5efvz
    Good idea. I will keep this tread going till this job is done.
  20. Aug 28, 2022 at 5:56 PM
    #40
    5efvz
    I know you already suggested me to change out the belt for another brand new one, but what percentage of risk am I taking by reusing this (fresh out of packaging) belt. I only did 3 cranks and they all lasted 5 second max.
