0-20 oil too thin?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yellowhonda, Nov 5, 2018.
  1. Dec 1, 2018 at 10:16 PM
    #221
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    hiPSI likes this.
  2. Dec 1, 2018 at 10:21 PM
    #222
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Remember that is the temperature where engines start, not where they run. With that said the discussed viscosity is fine for either application. The viscosity index of this oil is basically flat, meaning the engine in Arizona and the engine in Alberta will see close to the same viscosity when starting.
    The hammer likes this.
  3. Dec 1, 2018 at 10:23 PM
    #223
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The oil will be the same thickness at -30 and 130 degrees ......... ?
  4. Dec 1, 2018 at 10:28 PM
    #224
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    the oil temp in the sump is controlled by the cooling system capacity. Localized temperatures however such as bearings are not in that realm of control. The fastest way to increase oil temperature is to increase rpm. This increases the overall friction/ time equation and the bearing shearing the oil is frocti9n.. this heats the oil more than anything else.
    Higher Atmospheric temperature can cause the sump temperature to go higher bacuase the sump as a bulk is air cooled. Bit when circulated it gets exposed to higher or lower water jacket temperatures and helps control it somewhat. Oil to water coolers help some more.
    The oil viscosity recommendations based on temperature are just as true today, but the concept of viscosity needs to be updated since the wo,30,40,50,60 weights are way to broad an imprecise.
    A poster named Shannow from Australia on BITOG coined this terminology and it is a clearer way to discuss viscosity. Since cst@100c (what makes a 20,or 30 grade definition)is not really relevant to the high stress portion of an engine. When you shop for oil you simply take the winter rating and then look at the HTHS.
    It should be “x” w HTHS
    So 0w2.7 for 0w20
    Or 5w3.5 for acea a3 5w30
    I am about to add some 0w3.6 to my Tacoma for example and it is a quality a3/b4
    Taco16LB likes this.
  5. Dec 1, 2018 at 10:30 PM
    #225
    Bryanccfshr
    No it will be thinner at the Arizona temperature. The same oil gets thicker the colder it gets, regardless of viscosity index this is the physics of it.
    However, as long as it is still pumpable it is functional.
  6. Dec 1, 2018 at 10:34 PM
    #226
    Sharpish
    Brian
    An oil that flows (pumpable) at -30. Is this the best oil to cushion a bearing at 130 degrees, towing at max payload and max tow rating under the Arizona sun?
  7. Dec 1, 2018 at 10:43 PM
    #227
    Bryanccfshr
    It is more complex than that. High quality base oils can be used to produce a higher viscosity index product. But anything with a viscosity index greater than 170 becomes suspect due to the physical properties of base oils. to get a higher HTHS and a very low temp pump ability requires VII’s . So as you go up in n HTHS to get a stronger oil film and not one composed with VIIs you will need to increase the low temperature pumpabilty..or (decrease the spread) oils with less spread are indeed more oil and additives that count.
    As counterintuitive as it sounds finding high quality oils with lower viscosity index would better suit your needs. Their is no magic. So a synthetic 0w20 with a goof 150 is better than one with a V.I. of 180 you cannot break 170 without a lot of viscosity index improvers. The physical properties don’t allow it.
    Taco16LB and hiPSI like this.
  8. Dec 1, 2018 at 10:44 PM
    #228
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Can i have this pic? :D
  9. Dec 1, 2018 at 11:10 PM
    #229
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No, but the curve is much flatter than most other oils. You are thinking oils like molasses. Think of modern synthetics as like kerosene, much thinner and much more stable over temperatures. This oil actually has an acceptable pour point at -47C which is -53F. Years ago temps like this required thermocouples, blankets and heat tape, not to mention block heaters.
  10. Dec 1, 2018 at 11:13 PM
    #230
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    True.
  11. Dec 2, 2018 at 3:49 AM
    #231
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Our houses are not the great asset everyone thinks. If an owner mortgages, they’ll pay for the house about 3 times in 30 years, once the original price, once for mortgage interest and once for taxes/maintenance.
    Keeping a vehicle for 30 years I’m sure is similar (maybe 2X) with all the fees and maintenance.
    Sig45 likes this.
  12. Dec 2, 2018 at 4:18 AM
    #232
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I read the owners manual, I follow the owners manual. I do change change the oil and filter at 5000.00 miles, I know, I know.
  13. Dec 2, 2018 at 8:28 AM
    #233
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    That’s very misleading because most people don’t stay in their house for 30 years. They move several times.
    Obviously there are many factors involved such as location, development, local economy, home improvements, etc. however many houses will appreciate faster than their payments
    I have made money in every house I have sold. The profit being the the equity minus the payments made and upgrade/ maintenance costs.
    Comparatively if you bought a house for say 150k in 30 years it will likely be worth 300k-500k. Either way to get your money back.
    Real world example: my parents bought their first house back in the 80s and sold it in 97 for $134k, that same house sold in 2016 for $370k and is now estimated in 2018 for over $400k
    Taco16LB, hiPSI and shakerhood like this.
  14. Dec 2, 2018 at 8:40 AM
    #234
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Uh...yeah.
    And in addition to a house historically appreciating in value, you have to factor in the cost of rent you would have had to pay if you didn't own, since shelter is an actual need, along with food and clothing.
    Anyone care to debate the cost of food/ eating? The food I ate yesterday is practically worthless now in it's existing form.
    Keeping a vehicle for longer than average is actually saving money in the long run, even with the cost of maintenance factored in- imo. This statement is based on keeping up with scheduled maintenance.....and using recommend fluids...including 0 W20 oil....:crapstorm:
  15. Dec 2, 2018 at 9:02 AM
    #235
    Grossomotto
    2017 4WDV6LB6MT
    It was an example not taking into appreciation meaning worse case.
    Yeah mortgage companies love the 7 year turnover where “owners” pay the most interest.
    JoeCOVA[QUOTED] likes this.
  16. Dec 3, 2018 at 5:02 AM
    #236
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Check Craigslist.
    Woodrow F Call likes this.
  17. Dec 3, 2018 at 5:32 AM
    #237
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    But is it to the detriment of longevity?
  18. Dec 3, 2018 at 5:32 AM
    #238
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    One man's shit is another man's brown gold.....
    Right?
    :rofl:
  19. Dec 3, 2018 at 5:41 AM
    #239
    Woodrow F Call
    Colorful Colorado
    Especially if you are dumb enough to do the work yourself and not value your own time..... like this idiot here:
    I was thinking about what I'd do when the 3.5L does finally wear out..... I might be dumb enough to put some kind of LSx engine in it. That would be really dumb.... but fun.
    shakerhood and boynoyce[QUOTED] like this.
  20. Dec 3, 2018 at 5:42 AM
    #240
    Woodrow F Call
    Colorful Colorado
    Wow.
