0-60 Times
Discussion in 'Performance and Tuning' started by wildcats, Jul 21, 2014.
  1. Jul 30, 2014 at 5:40 PM
    #41
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Yeah he honestly sounds stupid
  2. Jul 30, 2014 at 7:30 PM
    #42
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    You went from a 3.00" to a 2.85' I'm assuming.....I'm sure you gained more air induction, and turned the screws faster, which should mean an increase in HP....if not you may have an underlying issue.....Torspd..you're up..!
  3. Jul 31, 2014 at 5:54 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Helped a friend with his s/c. After install of the new unit, it wasn't acting, or performing like it was making any boost. Told him to cap the vacuum hose which goes to the bypass valve. Voila. Instant boost. It was quite rewarding hearing the excitement in his voice. The bypass valve was staying open. Needed a new one.
    For testing sake, you could try the same. Yours might possibly be partially stuck open perhaps? I know that we had discussed other possibilities, such as elevation.
  4. Jul 31, 2014 at 6:03 AM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lucario Runner makes ~250ish whp and ~300ish wtq with N/A bolt-ons. Has the same 3.73 gears. Races autocross and on two different road courses, in his 4Runner w/4.0L. And can still get 24 mpg. I have other friends whom have done similar mods but with the 6 spd manual Tacoma, and can get similar mpg.
  5. Aug 1, 2014 at 9:12 AM
    #45
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I assume you mean to cap the bypass valve itself and not the vacuum line, right? Pretty sure that's what you meant but the way it's worded sounds like you're suggesting leaving the valve itself open to the atmosphere and then cap the vacuum line that was connected to it?
  6. Aug 1, 2014 at 9:45 AM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct. Primarily the vacuum source.
  7. Aug 1, 2014 at 10:51 AM
    #47
    Ostrichsak
    Jer
    Wait, which part was correct? lol
    1. Just leave the valve uncapped and cap the vaccum line so there are no vacuum leaks in the system?
    2. Cap the valve & leave the vacuum line uncapped.
  8. Aug 1, 2014 at 11:10 AM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just cap both for testing.
  9. Aug 1, 2014 at 11:45 AM
    #49
    Ostrichsak
    Jer
    I'll try it out.
  10. Aug 6, 2014 at 8:43 AM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any difference, or no?
  11. Aug 6, 2014 at 9:32 AM
    #51
    Ostrichsak
    Jer
    I haven't even had a chance to test it yet to be honest. The truck has sat in the garage and I've just been driving my other cars until I get more time to tinker. In somewhat related news I do have a Check Engine light that flashes a few more times after start up than it used to. I recently had to replace my battery and it started shortly after that so I just chalked it up to sensors being reset and needing to re-adjust parameters but now I'm wondering if it's not throwing a code for that bypass valve maybe. I'll need to pull a code to see what sensor is throwing it. The acceleration remained unchanged as compared to when I replaced the pulley with the smaller one.
  12. Aug 7, 2014 at 8:36 PM
    #52
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I don't think anyone has ever done a 0-60 run with a little 2.7 before, so I did one. :)
    https://www.youtube.com/watch?v=cHlV9FSipzM
    I just did a regular full throttle start without popping the clutch or speed shifting. Second gear gets it past 60 so it's just one shift.
    Elapsed time: 10.0 seconds. :)
    Greg
    Edit: Correction, Gelo also did a 2.7 run. ;)
  13. Aug 7, 2014 at 11:19 PM
    #53
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    DocME likes this.
  14. Aug 7, 2014 at 11:49 PM
    #54
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    They technically have done this, BUT they have just, quite stubbornly kept the Duel vvti variant of the 1gr-fe found in later model Fj cruisers and 4runners out of the tacoma for no good reason. Duel vvti Added another 20hp/20ft/lb of torque, improved mpg, and eliminated the need for a secondary air injection system since the exhaust cam vvti coupled with the intake vvti drastically improves the burning of the fuel. Toyota really missed the boat on that opportunity because I for one think it was the smarter, better thing to do to add to the facelifed 2012+ tacos instead of the stupid and irritating secondary air system
  15. Aug 8, 2014 at 6:08 AM
    #55
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good heads, mated to a terribly executed bottom end. The dual VVT-I engine. Shouldn't even be called the 1GR.
    Moving Moose!
  16. Aug 8, 2014 at 7:01 AM
    #56
    Ostrichsak
    Jer
    If it ain't broke...
    The problem is there is NO competition in the segment. They can't make Tacomas fast enough to meet demand so no need adding anything new if they don't need to. If/when someone else makes something to actually compete they've got plenty of aces up their sleeve to bring customers back over to their side before the competition can take any market share. I'd love lots of upgrades but that also can come with a sacrifice in reliability overall and/or a price hike. As much as I would like all sorts of features and options in my Tacoma I'm quite happy with it over other vehicles I've owned that have had more wizz-bang options.
  17. Aug 8, 2014 at 10:45 AM
    #57
    kyleTRDtaco12
    Kyle
    New Jersey
    [QE=Ostrichsak;9015037]If it ain't broke...
    The problem is there is NO competition in the segment. They can't make Tacomas fast enough to meet demand so no need adding anythinsen
    PHP:
    hey don't need to. If/when someone else makes something to actually compete they've got plenty of aces up their sleeve to bring customers back over to their side before the competition can take any market share. I'd love lots of upgrades but that also can come with a sacrifice in reliability overall and/or a price hike. As much as I would like all sorts of features and options in my Tacoma I'm quite happy with it over other vehicles I've owned that have had more wizz-bang options.[/QUOTE]
    Adding a the duel vvti variant would never sacrifice reliability when that engine has been proven already in the fj cruiser and 4runner, toyota already did this in the fj cruiser because the cruiser had the single vvti variant, our exact 4.0s for the first two years of fj production, then toyota realized they messed up because the engine didnt make enough power since the fj is heavier than the tacoma, sooo they put a duel vvti variant in there up until now that the fj is going out of production, it could easily be done because its been done before, wouldn't be difficult for them, definitely would never sacrifice reliability, it could actually only better it, and no crap emissions pump And it would have kept more room in the engine bay as well as kept other components the same such as brake and A/C lines as well as the ABS pump position, also, price really wouldn't be affected that much because all that changed is an existing engine, and an ECU which is also already existing... and lastly, as far as competition goes, toyota should have bumped the power up years ago because the frontier is still beating the tacoma on the power front, even if tacoma sales are better, duel vvti would have been the simpler, cleaner way to make the 4.0 emissions compliment in 2012 + tacomas. it literally just makes sense
  18. Aug 8, 2014 at 10:48 AM
    #58
    Ostrichsak
    Jer
    My point about reliability was more of a generalization when you have a proven object. Any time you make changes you introduce unknowns and there's no saying that more power won't decrease the life of the drive line or some other component. The primary point is if you can't build enough of the object to meet demand why would you do anything other than try to meet demand?
  19. Aug 8, 2014 at 10:55 AM
    #59
    kyleTRDtaco12
    Kyle
    New Jersey
    Its really not going to affect anything... that duel vvti varient has been used for years in the 5th gen 4runner and fj cruiser with no troubles, toyota already swapped a single for a duel with the fj cruiser in mid production with no trouble at all, I really dont see your point here.
  20. Aug 8, 2014 at 11:00 AM
    #60
    Ostrichsak
    Jer
    You're speaking in specifics. I'm speaking in generalities so that's probably why you fail to see my point. I'm also talking about a corporation who's sole purpose for existence is to make profit. If you can't understand the simple idea of supply v demand and how it affects corporate decisions then I'm not sure how to help you here. I know you think Toyota hates us and that's the only reason but there are far bigger reasons than you can comprehend at play here.
