0-60 Times
Discussion in 'Performance and Tuning' started by wildcats, Jul 21, 2014.
  1. Aug 13, 2014 at 12:56 PM
    #121
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This. I've been wanting to forever now. just to find an area and practice switching out of 4wd while still accelerating. Seems tricky and risky but I think I'm over thinking it. Lol
  2. Aug 13, 2014 at 1:03 PM
    #122
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I don't think you need to at only 60mph.
  3. Aug 13, 2014 at 1:06 PM
    #123
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    True. I was thinking just a full like quarter mile launch.
    I have used 4hi up to ~75mph. So it definitely works for that. Anything above tho.. idk
  4. Aug 13, 2014 at 2:21 PM
    #124
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Werty always switched out on the track. Being automatic, it is very easy.
    Try switching out with a manual, between shifts. That needed much more practice. Phew. Good thing I plan on being AWD..... :drevil:
  5. Aug 13, 2014 at 9:07 PM
    #125
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    cant wait for this to happen.. :D
  6. Aug 13, 2014 at 9:34 PM
    #126
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    If I try a launch in 4wd and flip the switch while under power it doesn't come out.
  7. Aug 13, 2014 at 10:09 PM
    #127
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Watch wertys videos and do it the same time he does?
    Iirc to on of 2nd gear right?
  8. Aug 13, 2014 at 10:14 PM
    #128
    memario1214
    Colton
    Missoula, MT
    Yeah I've tried. No dice
  9. Aug 14, 2014 at 8:38 AM
    #129
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    I think that's a manual only trick
  10. Aug 14, 2014 at 8:39 AM
    #130
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    driver mod
    never mind I read through more
  11. Aug 14, 2014 at 8:50 AM
    #131
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    It works on mine. When the AT switch to 3rd gear, i switch back to 2wd.
    Biscuits and WOODEX M.E. like this.
  12. Aug 14, 2014 at 1:09 PM
    #132
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Are you manually shifting through the gears or in "D"?
  13. Aug 15, 2014 at 1:27 AM
    #133
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I ran a 8 second with 32" coopers.... I think I'm almost back to stock after adding the tires.. Just installed my urd maf cal I will see if this helps...
  14. Aug 15, 2014 at 4:26 AM
    #134
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tuned in properly, you can pick up between 10 - 15 hp. Not sure how much torque. That will help though.
  15. Aug 15, 2014 at 1:17 PM
    #135
    shr133
    Muskego, WI
    2010 V6 Sport
    First tune (with about 10-15 tweaks) on the MAF is working good. and I have more accurate data. I recorded video with my sony action cam, had to go to edit mode on the video to get accurate times down to the tenth, 8.04 and 8.10 before and 7.23 after adding the MAF cal and I'm still tweaking the map but I'm real close...
    But a solid 8 tenths faster is great and I'm not done tuning and that was after a 70 mile test and tweak drive, mid after noon.
    Helps drivability and power at all speeds...
    Real time data makes tuning the MAF cal easy....
  16. Aug 15, 2014 at 6:13 PM
    #136
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    I pulled out of 4hi around 85mph in 3rd gear. The reason I chose 3rd is because 1st and 2nd went by too quickly, and I didn't want it to drop into 2wd right in the middle of a shift. As soon as it drops back to 2wd you can feel the truck pick up speed.
    and for the record...I did do a few runs all the way in 4hi when I was first trying this...so Ive gone over 100 mph in 4 hi. But applying brakes when in 4hi at those speeds felt very scary...I would not recommend it
  17. Aug 15, 2014 at 7:15 PM
    #137
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    man how did i forget about the MAF cal.. I still need one.. :(
  18. Aug 18, 2014 at 5:24 AM
    #138
    Vassily28
    Hi Werty,
    We can see that you're shifting manualy your AT. Do you shift at lower rpm than the AT or you're shifitng later at higher rpm?
  19. Aug 18, 2014 at 8:22 AM
    #139
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    Shifting at 6200 rpm;)
  20. Aug 18, 2014 at 1:01 PM
    #140
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    :eek:
