0-60 Times
Discussion in 'Performance and Tuning' started by wildcats, Jul 21, 2014.
  1. Aug 18, 2014 at 1:16 PM
    #141
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    Do a 2.55 Pulley and get the snake bite mod down to your supercharger :D
    Torspd likes this.
  2. Nov 25, 2014 at 9:16 PM
    #142
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    hey guys, what is MAF cal., how do i do it and what is torque app?
  3. Nov 25, 2014 at 10:05 PM
    #143
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
  4. Nov 25, 2014 at 10:24 PM
    #144
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Do you know If this will work with a 6speed manual??
  5. Nov 26, 2014 at 5:21 AM
    #145
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I did it like that at the Track a few times, before I swapped transmissions. It worked for me as well. Timing the selector between shifts was the hardest part. As I hadn't had enough practice.
  6. Jan 14, 2015 at 11:19 PM
    #146
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
  7. Oct 11, 2016 at 9:47 PM
    #147
    djniere
    djniere Well-Known Member
    David
    Temple, TX
    2016 RAM 2500
    Stock boi
    IMG_6041.jpg If i go off the speedo its 6.8. If i go off the scangauge mph its 7.2. Mods are air raid intake, DT pipe bomb y pipe, borla catback and urd maf cal that i got a map from another user that i modified for my AFR. Tires are 265/75/16 dynapros
    shr133 likes this.
  8. Oct 11, 2016 at 10:18 PM
    #148
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    :) ok, ok. Its not my tacoma.
  9. Oct 13, 2016 at 10:12 AM
    #149
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    This is exactly what I do when I want to show my friends what my truck can really do. Brake boost and then lift off the brake pedal and away it goes. Most the time you cant get that kind of thrust because one or both of the rears just let go.
  10. Oct 14, 2016 at 6:14 AM
    #150
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. That is the reason that Super Werty had the longest held quickest 1/4 mile time. Considering his power to weight. Not until a manual RWD with a lot more power, and really good driver combined, and appropriate traction mods, was it surpassed.
    History proves that it is hard to beat the auto, with manual shifting, and 4x4 launches.
    XPOTRPR likes this.
  11. Mar 15, 2017 at 11:17 AM
    #151
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    So I'm going to be installing a urd maf cal and a urd true cold air intake. I have my tablet displaying torque pro from a Bluetooth Odb 2 scanner. I'd like to get 0-60 times from a) stock b) maf cal c) maf cal and cai. My question is how do get the most accurate times for all. I'd also like a step by step of how to launch with 4x4 engaged, shifting manually, on a auto. I understand the basic concept.... Just don't want any surprises. Any and all info/links are appreciated.
  12. Mar 15, 2017 at 12:04 PM
    #152
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Load the torque converter. Shift when you see fit. For me with the valve body upgrade, my shift point is a little higher now.
  13. Mar 15, 2017 at 12:23 PM
    #153
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Around when should I be looking to disengage 4x4? Would I have to let off the gas as it disengages?
  14. Mar 15, 2017 at 2:33 PM
    #154
    WOODEX M.E.
    Corey
    Maine
    Don't bother, when you make it to 60 let off and coast or whatever depending on the speed limit then gently shut it off. It's not like you are doing a quarter mile. Also I would just let the truck do the shifting. It will be the same every time and you won't bounce off the rev limiter.
  15. Mar 15, 2017 at 5:24 PM
    #155
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    No need to disengage 4wd. Manual shifting lets you get allllll them rpm's.. Its not difficult.
    There is a big difference when manual shifting. I've played with both methods when we go to the sand drags.. Pretty regularly.. And manual ftw
    Thyces likes this.
  16. Mar 16, 2017 at 4:09 AM
    #156
    Thyces
    Ontario
    2009 DCLB TRD Sport
    In stock I wouldn't imagine that much of a difference in shifting manually or letting the truck do it. With the maf cal I would think the longer it's in open loop the more I'd get out of it and from my understanding that doesn't kick in until at least 4500 rpm.
    I'll try both today as it's still stock and see what I get. Thanks for the info.
  17. Mar 16, 2017 at 4:26 AM
    #157
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Manually shift. :thumbsup:
    XPOTRPR and Thyces like this.
  18. Mar 16, 2017 at 8:17 AM
    #158
    Thyces
    Ontario
    2009 DCLB TRD Sport
    8.55 4x4 on, not loading converter, just dead stop and flooring it. K&n drop in filter and magnaflow muffler. 5100lbs at the recyclers scale half tank of gas. I'll try manual shifting on my next one.
  19. Mar 21, 2017 at 9:01 PM
    #159
    shr133
    Muskego, WI
    2010 V6 Sport
    1st do a few launches or drive more aggressively to tell the computer that grandma time is over, so it knows to go when it's time to go.
    Load the converter and launch in 2wdr.
    I was letting it shift it's self with the stock intake was the most consistent.
    it may take a bunch of pulls to get a good time so let it cool back down after a few runs.
    With the intake on it will pull much better so manually shifting may be better with the intake on.
    When you add the maf cal you may start spinning the tires so you may have to heat the tires up and or lower tire pressure.
    Open loop will kick in as soon as you hit the gas so the maf cal can cut lots of time I dropped about 1 second.
    I may be doing 0-60 times again when it warms up. now I have a volant intake, new trans fluid, unichip and 33s, so I hope I can back to where I was with the 32s.
    Thyces[QUOTED] likes this.
  20. Mar 22, 2017 at 4:03 AM
    #160
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks for the info. How's the unichip? I've heard nothing but bad things about it.
