0-70+, Stock 4.0, 3.73, 37" tires, 7.5% grade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DG92071, Jan 3, 2020.
  1. Jan 3, 2020 at 4:12 PM
    DG92071
    DG92071 [OP] Well-Known Member
    As the title says, a stock 2006 Tacoma PreRunner, 4.0L V6, automatic transmission, stock open 3.73 gears, 37/12.50R17 BFG KO, from a dead stop to 70+ mph on a 7 1/2% grade.
    There are far too many posts about how slow it should be, but for the people wondering how the acceleration rate is before they mod their truck, here's mine.
    It's the answer to the 1,000+ posts "I don't tow, I don't off road hard, will I need to regear my truck if I install 33's or 35's?".
    https://rodshot56.wistia.com/medias/f0jieecreq
  2. Jan 3, 2020 at 4:52 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    It’s actually not that bad. :)
    DG92071[OP] likes this.
  3. Jan 3, 2020 at 5:13 PM
    DG92071
    Looked like around 10 seconds 0-60 going up that 7.5% grade. On flat ground the 0-60 is 7.27 seconds. Stock tires on a (flat) track is 6.8 seconds.
    One of these days, before I change the gears, I'm going to do the exact same thing with a trailer in tow.
    gotoman1969 likes this.
  4. Jan 3, 2020 at 5:25 PM
    DG92071
    I tried to do the same type video on flat ground, I tried 3 times, every time I hit the go pedal hard the video stopped recording on my expensive android. ???
  5. Jan 3, 2020 at 5:28 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    Not bad at all for 37s. Got a pic of your truck? Also I wonder if a 4x4 would be any slower because of the added weight and whatnot?
  6. Jan 3, 2020 at 5:41 PM
    DG92071
    Taken today.
    I really didn't know what to expect but for what it is it's really not bad at all.
    According to the websites I looked at the 4X4's had the exact same 0-60 as the PreRunner.
    I really wanted a video of 0-60 on flat ground with my Pedal Commander turned on, it has to be at least as good as stock tire 0-60, according to my opinion for now...
  7. Jan 3, 2020 at 5:42 PM
    DG92071
    And thank you.
  8. Jan 3, 2020 at 5:55 PM
    DG92071
    Idk I thought it was funny so I'm sharing it.
  9. Jan 4, 2020 at 7:16 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Absolutely it would. I'm just guessing but you're probably looking at 700# more weight.
    Ccrames2018[QUOTED] likes this.
  10. Jan 4, 2020 at 7:19 AM
    DG92071
  11. Jan 4, 2020 at 7:24 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Bfg’s run very small. They look smaller than my 35’s. Still a cool video though! I never felt the need to regear
    KILLINTIME and DG92071[OP] like this.
  12. Jan 4, 2020 at 7:27 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I have the same grade on my daily commute, for a heavier truck (compared to the truck I used to drive) it does really well. It will cruise along 60mph and stay in gear. If you need to pass a truck it will do just fine. Always keep it in D4 up and down, it holds the truck really well going down the mountain.
  13. Jan 4, 2020 at 7:27 AM
    DG92071
    BFG KO 37's are 36.5"
  14. Jan 4, 2020 at 8:21 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Do you have a spindle or db lift? Hard to tell from the pic.
  15. Jan 4, 2020 at 9:13 AM
    DG92071
    I have zero interest in having any online conversation with you as you have no positive intentions whatsoever. It's a PreRunner, remember?
    https://youtu.be/uuti-PrM4Tg
    I love the douchebag's comments in the background of the video around 1:15, what a dumbass that ate his own words... but it doesn't matter because mine is a mall crawler for now anyway.
  16. Jan 4, 2020 at 9:52 AM
    DG92071
    I made a few mistakes in this video.
    1. My inclinometer measured the incline at 4.7 degrees but a county road sign lists it as 6.
    2. Wear your seatbelts.
    3. The truck is not completely stock with only blocks and spacers because it also has high caster UCA's.
    https://rodshot56.wistia.com/medias/alzmmhykpq
