0% ethanol fuel give better mpgs in a V6?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amocat21, Dec 2, 2014.
  1. Dec 2, 2014 at 3:06 PM
    amocat21
    amocat21 [OP] Active Member
    2012 6 cylinder 4x4
    Anyone notice better mpgs in their V6 running 0% ethanol fuel(clear gas) or are the new trucks made for 10% ethanol only?
  2. Dec 2, 2014 at 3:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes , 0 ethanol is better
    drizzoh likes this.
  3. Dec 2, 2014 at 3:27 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    I pay the extra .15 a gallon for it. Its much better and more responsive along with better mpg's on the highway for sure.
  4. Dec 2, 2014 at 3:34 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    wish I had a local ethanol free station here.. :pout:
    drizzoh likes this.
  5. Dec 2, 2014 at 3:49 PM
    taco 2011
    taco 2011 Well-Known Member
    Alabama
    2011 Toyota Tacoma TRD SR5
    Westin Bull guard,predator nerf bars, Window Tint Legal limit, Weather tech Floor mats, Weather tech smoke visors, Wet Okole seat covers, OEM Roof Racks, Reverse Camera, Pace Edwards Full Metal Jack Rabbit Cover,Dyno power locking tailgate Trd alloy wheels, Dunlop at tires JL Stealthbox, JL custom fit molding kit, Directed Audio 500 watt amp, LCI adaptor. More mods to come.
    This:rant:
  6. Dec 2, 2014 at 4:00 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I use the pure gas (E-0) and average about a 10% increase in mpg with it over E-10. I make sure it is a TOP TIER Detergent Gasoline brand.
    http://www.toptiergas.com/index.html
    My only problem is I have to haul the gas into my location. I drive around 85 miles one way to pick it up and bring it back about once a month. I run it in all my vehicles as well as boat, and yard tools.
  7. Dec 2, 2014 at 4:01 PM
    Marky
    Marky Well-Known Member
    Roanoke VA
    2014 DCLB Super White
    FLTruck's 2014 OEM Nav upgrade!
    According to my really quick search, ethanol has about 2/3 the chemical energy of gasoline. So if you fill up with 10% ethanol mix, your tank contains 96.7% of the energy it would have if you had filled it with straight gas. That percentage should translate directly to mpg. So you're giving up between 3 and 4 percent of your mpg when buying ethanol mix, and if the pure gas costs more than that, you're losing money.
    Around here the 10% stuff is going for about $2.60 per gallon. So if pure gas is more than $2.70, it's not worth it, from a pure cost perspective anyway. I have no idea what the long term effects of ethanol are.
    Marc70 likes this.
  8. Dec 2, 2014 at 4:09 PM
    savedone
    Gerald
    Texas
    Wow if the E-0 is only a dime more where you are it is well worth the price. Here it is around 30 to 50 cents more per gallon and I still feel it is worth the price in the long run.
    As to effects, on my boat I had special gas line installed that was suppose to handle E-10 and it still wept through with the E-10 over a years time. That and the increased MPG on my vehicles is what made me make the change.
    Here are some issues with E-10 and above.
    http://offers.bellperformance.com/ethanol-problems
  9. Dec 2, 2014 at 4:16 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Yes and I keep a can around for the yard equipment. Freakin' ethanol gums up the carbs on lawnmowers in pretty short order.
  10. Dec 2, 2014 at 5:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah here in CA we have no choice but E10.
  11. Dec 2, 2014 at 5:19 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    This^ ethanol will not hurt any thing they are designed to burn it.
  12. Dec 2, 2014 at 5:20 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ethanol is a solvent it can't gum things up.
  13. Dec 2, 2014 at 5:24 PM
    bicyclist
    bicyclist Well-Known Member
  14. Dec 2, 2014 at 5:34 PM
    bicyclist
    Ethanol won't hurt engines designed to burn it, but there are plenty of small engines that are not.
    Ethanol absorbs water and is corrosive to aluminum. BMW has had problems with motorcycle fuel pumps and fuel injectors clogged with oxides of aluminum particles.
  15. Dec 2, 2014 at 5:41 PM
    pavemobile
    pavemobile Well-Known Member
    Wichita Falls, Texas
    2009 TRD Sport SR5 PreRunner
    K&N Intake
    My V6 gets 2.5 - 3.5 mpg better on ethanol free when I can find it and much better throttle response and power.
  16. Dec 2, 2014 at 5:48 PM
    FooBird
    FooBird Well-Known Member
    Kirkland, WA
    '14 DCSB 4x4 TRD Off Road
    I like it if it's worth it price-wise. I luckily have a no ethanol station 2 blocks from my house. But lately it hasn't come down in price like the other stations.
  17. Dec 2, 2014 at 5:58 PM
    Bajatacoma
    SC
    While you are technically correct, ethanol is simply an alcohol, you are creating a straw man- what we are talking about it the ethanol "enhanced" or blended fuels which are not pure ethanol since they contain mostly gasoline. Ethanol is hygroscopic meaning it binds with water and in short it does lead to gumming of small motors that are vented and tend to sit for extended periods of time such as lawn mowers and boat motors. It's not nearly as big of a deal for modern vehicles with closed systems.
    Also you might want to tell these guys that since they apparently didn't get the newsletter. Just some of the examples out there including the National Marine Manufacturers Association, Briggs & Stratton and Yamaha.
    http://saturdaymechanic.com/ethanol-issues-varnish-vs-gum-and-using-the-right-additive/
    http://jalopnik.com/5043482/ethanol-in-gasoline-reportedly-wreaking-havoc-on-small-engines
    http://atvsinacadiana.weebly.com/ethanol-issues-in-small-engines.html
    http://northshorefishingreport.com/articles---ethanol-and-engine-maintenance.html
    http://opei.org/the-national-marine...k-before-you-pump-ethanol-education-campaign/
    http://www.fuel-testers.com/marine_boat_ethanol_problems.html
    http://www.yamaha-motor.com.au/faq#t13n1163
    Here's what Briggs & Stratton have to say about it:
    http://www.briggsandstratton.com/us...gines/the-latest-in-fuel-treatment-technology
  18. Dec 2, 2014 at 6:03 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    E10 is like 3.2 beer (if you're old enough to know what that is). It looks like beer, it smells like beer, it kinda tastes like beer, but it's just not as potent!
    Marc70 likes this.
  19. Dec 2, 2014 at 6:18 PM
    SuperKevin11
    SuperKevin11 Active Member
    Kevin
    Chattanooga, TN
    2019 Tacoma Double Cab 4x4 TRD Offroad Premium Cement
    I agree. Additionally: Ethanol has less energy content than petroleum. However, it has a higher octane which will accommodate a higher compression ratio. If our engines were more optimized for ethanol (E10), then they would achieve more HP than they do as built for both E10 and E0. I had a Ranger with a Flex Fuel engine and my plan was to install a Supercharger and change the pulley for more boost for use with E85. However, E85 was never available in my area and then I bought a new Non-Flex Fuel truck. The dream died. Haha!
  20. Dec 2, 2014 at 6:34 PM
    FooBird
    Kirkland, WA
    Glad to see the appropriate use of "hygroscopic". I remember my plastics classes back in college and people would argue about the hygro vs. hydro.
    Although I can't speak to the Tacoma V6 because I don't have the depth of data (15 tanks of gas), but I know my Honda sounds and feels better on the whole with the E0 gasoline. There is no statistically significant difference between the data populations of E10 gasoline I've put through there and the E0 over 45k miles of tracked fill-ups (70 tanks of E0 and 90 tanks of E10). The variance in the populations from "normal driving condition variation" beats out the expected difference of 3% that you would think coming from the energy density math. I see trends but I cannot stand up and say so with any decent level of confidence.
    Before the supercharger, there was a noticeable difference between 87 and 92 octane for me on the Tacoma. Perhaps associated with the engine knock? I never hooked up the OBDII reader to see what the knock count was (if there was any).
