0 to 60 Horsepower Calculator
Discussion in 'Performance and Tuning' started by shr133, Jan 14, 2015.
  1. Jan 14, 2015 at 11:17 PM
    shr133
    shr133 [OP] Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    This calculator is cool, after putting 32s on my truck it was a dog so I went on a tuning mission and I estimated that I added about 25HP but haven't made it to a dyno. During the 0-60 thread my truck was running 8.1 and adding the MAF CAL from URD got me down to best of 7.05.... WOW...
    But how much HP is that.... HP is a measure of work so I figured there has to be a calculator for that and boom first click I found a cool one..
    Stock we have 236 and the truck runs 7.7 0-60 and the calculator is dead on..
    I'm up to 269 at the crank, +33 sweet.... :cool:
    Here's the link see what you are up to....
    http://www.060calculator.com/
  2. Jan 15, 2015 at 6:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not bad with a little tuning. :thumbsup:
  3. Jan 15, 2015 at 12:17 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    interestingly it seems close.
    using the torque app set on GPS speed, I got this (second launch) of 5.8 seconds.
    https://www.youtube.com/watch?v=uvB3HtyI4vA
    according to the calculator, to achieve 5.809 seconds, at 4400lbs, Im supposed to be at 365 at the flywheel.
    I always figured 350, so this isnt too bad.
  4. Jan 15, 2015 at 11:54 PM
    shr133
    Muskego, WI
    2010 V6 Sport
    This calculator cool....
