00' enigine removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by yummjake, Mar 11, 2010.
  1. Aug 30, 2010 at 10:40 AM
    #41
    98tacoma27
    Ben
    Not Beech Creek
    P0171 is a Lean condition. I am not sure what you 67-75 numbers mean in regards to a reading.
  2. Aug 30, 2010 at 11:14 AM
    #42
    yummjake
    yummjake [OP] Well-Known Member
    Jacob
    Richmond, VA
    00' EXT Tacoma 4wd
    5100's, Toytec coils, all-pro standard 3" lift leaf springs.
    Knew i was forgetting something, the numbers are for Sensor 2 Bank 1. Sorry, we had known what the code was, just making sure everything lined up. thanks.
  3. Aug 30, 2010 at 11:23 AM
    #43
    98tacoma27
    Ben
    Not Beech Creek
    Sensor 2 is an O2 sensor and won't have anything to do with that code. I still don't known what the reading are for on the scangage2. Does it tell you in the manual what they mean?
  4. Aug 30, 2010 at 12:22 PM
    #44
    yummjake
    Jacob
    Richmond, VA
    00' EXT Tacoma 4wd
    Okay, on the scangauge we have the following "gauges" set-up: A/F ratio, Short Term Fuel trim, Long Term Fuel trim, and O2 sensor. We noticed one thing while on a test run, We noticed that the O2 sensor's reading were bobbing up and down the most, the other gauge's reading's were fairly steady. The O2 sensor we are monitoring pretty much for giggles, one more thing that could help us. The fuel air ratio at idle was around 14. 3 -14.53, Long term fuel trim, 27, short term, -8, O2 sensor, 65-75. Thanks again for any and all help.
  5. Aug 30, 2010 at 6:53 PM
    #45
    98tacoma27
    Ben
    Not Beech Creek
    Are these custom gauges?
  6. Aug 30, 2010 at 7:12 PM
    #46
    vicstacoma
    vicstacoma Guest
    I got this same code on my 2000 toyota tacoma and it ended up being a vacuum leak between air cleaner and throttle body. As soon as I fixed leak everything has been fine. But the most common thing when you get a p0171 is a bad maf sensor. It can either be dirty and needs to be cleaned or you need to replace the whole sensor. Good luck.
  7. Aug 31, 2010 at 6:45 AM
    #47
    yummjake
    Jacob
    Richmond, VA
    00' EXT Tacoma 4wd
  8. Sep 1, 2010 at 3:25 PM
    #48
    yummjake
    Jacob
    Richmond, VA
    00' EXT Tacoma 4wd
    Okay, we are no longer (knock on wood) gettting p0171, now we are getting p0420, i don't think my truck is a stoner :confused: :p, wondering if there are any ideas to fixing this problem/ code. As always any and all help is welcomed. Thanks again.
  9. Sep 2, 2010 at 6:54 AM
    #49
    yummjake
    Jacob
    Richmond, VA
    00' EXT Tacoma 4wd
    bump. anyone?
  10. Sep 2, 2010 at 10:16 AM
    #50
    98tacoma27
    Ben
    Not Beech Creek
    There can be several causes to this code, bad AFR sensor, exhaust leak(s), and of course a bad CAT.
  11. Sep 2, 2010 at 6:55 PM
    #51
    yummjake
    Jacob
    Richmond, VA
    00' EXT Tacoma 4wd
    Well we replaced the O2 sensor( the rear most one) and have clocked 60ish some miles on her with it like that, no lights. Hopefully that will be the end of my problems. During those miles there were at least 6-7 engine "cycles" (on, run, off, repeat). Love driving this truck, two days till i'm able todrive it on my own. haha, thanks for all the help i have gotten.:D
  12. Sep 3, 2010 at 6:00 AM
    #52
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Did you replace the torque converter seal and drain the trans before installing the engine?
