00016-35220 Fog Light Kit 2012-13 Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLAJIM, Apr 11, 2013.
  1. Apr 11, 2013 at 10:12 AM
    FLAJIM
    FLAJIM [OP] Well-Known Member
    Jim
    Daytona Beach, Fl.
    2012 PreRunner SR5 2WD
    ARE tonneau cover, Electric Pop & Lock tail gate, 2 lighter plugs in bed, Reese hitch/ factory wiring, OEM Bed Extender and fog lights.
    I bought the 00016-35220 Toyota Tacoma Fog Light Kit 2012 - 2013 and installed it in my 2012. Works great, but I very much want to do the mod that lets you turn on the fog lights with just the parking lights. Can someone please tell me if there is a way to do this. I have read the mods for the factory installed lights but this kit is different. Thanks in advance for any help.
    Be Safe JIM
  2. Apr 11, 2013 at 6:08 PM
    FLAJIM
    Jim
    Daytona Beach, Fl.
    I guess nobody knows...... Damn !!
    Be safe JIM
  3. Apr 21, 2013 at 9:03 AM
    cshughes79
    cshughes79 Active Member
    chuck
    Tri cities, va
    2012 tacoma 4x4 double cab
    nerf bars;3" toytec lift 885 coils and Ol Man Emmu shocks in the front add aleaf in the rear
    I am looking for the same answer! Anybody out there please HELP!!
  4. Apr 21, 2013 at 2:09 PM
    FLAJIM
    Jim
    Daytona Beach, Fl.
    I don't think its going to be answered...... been looking all over the web with no answers.
    JIM
  5. Apr 28, 2013 at 11:05 PM
    inthebag87
    inthebag87 Active Member
    Jake
    Texas
    '12 PreRunner
    FLAJIM i have a question about the kit. Does the$149.95 kit come with fog lights for both sides or do you have to buy two?
  6. Apr 29, 2013 at 4:24 AM
    FLAJIM
    Jim
    Daytona Beach, Fl.
    !49 is complete, 2 housing, 2 lights, wiring and switch. Great deal Be Safe JIM
  7. Apr 30, 2013 at 6:43 AM
    cshughes79
    chuck
    Tri cities, va
    Might have a answer on the mod for fog lights on anytime in a day or so, called a local shop that installs this kit in tacomas and do the mod meeting with them tomorrow to see what he can do. i will update after i talk to him!
  8. Apr 30, 2013 at 7:04 AM
    FLAJIM
    Jim
    Daytona Beach, Fl.
    That would be so GREAT !!! Please keep me updated.
    Be Safe JIM
  9. May 1, 2013 at 12:42 PM
    cshughes79
    chuck
    Tri cities, va
    I finally have the FOG lights on anytime, basically pulled out the wiring that goes to the relay under the dash, orange and black cable with Diode in it and few other cables had to rewire the hole thing to get it to work. I will try and take pictures in the next couple of days to show u what i mean.
  10. May 1, 2013 at 12:48 PM
    FLAJIM
    Jim
    Daytona Beach, Fl.
    Great news it can be done. Please post as much instruction as you can. I really don't want to short something out. Looking forward to see your reply.
    Thanks again, JIM
  11. May 1, 2013 at 1:45 PM
    inthebag87
    Jake
    Texas
    '12 PreRunner
    Thank you very much for the response. I wasn't sure about buying this set up but now I will buy this next pay day ha.
  12. May 1, 2013 at 6:47 PM
    coma09
    coma09 Updated avatar
    BC Canada
    2013 taco access cab 4x4
    eBay. $99 with harness, relay, bulbs, and oem style switch that fits in the Oem holes with no alterations.
    Lenses are glass. The quality surprised me.
    All I needed were tie wraps.
    Watch the kits on eBay. Some have a cheap round switch, and others have the oem style switch.
  13. Sep 12, 2013 at 8:56 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I am about to get this same kit from a Toyota dealer and install it myself on a 2013 RC,
    I would think you just need to find the wire that tells the relay to turn on, and run it to a know hot wire of your choice.
    I would like to be able to run them with my DRLs sometimes...
    Guess we will see. I know there is a free PDF download of the factory 2013 Electrical manual on TW now, it has been a huge help.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/278185-2013-tacoma-electrical-wire-diagrams.html
  14. Sep 12, 2013 at 9:38 AM
    Greenbean
    Zack
    Western NC
    This is the page in the PDF from above,
    The standard instructions for the kit you have and the kit I am using it gets the power from the headlight low beam power, see pic one, it's the wire going into the PIN 35 of PLUG IA1,
    The second pic is just the white wire being used and it's for ground purposes. PIN 29
    This the text from the PDF of the instructions.
    One advantage of wiring this way is well it's within the state laws yadda yadda yadda, but also the lights will turn off like your lights already do when you turn the ignition off and open the door,
    I myself want them to be able to be turned on with my parking lights...
    T-tap orange/black wire from fog light
    harness to connector IA-1 pin 29, white
    wire. Connector IA-1 is located in the upper
    kick panel area (pictures 15 and 16)
    16. T-Tap the green/black wire from fog light
    harness to connector IA-1, pin 35, red-black
    wire (picture 15 and 16)
  15. Sep 12, 2013 at 2:40 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    ^^^^That's all I did, find the hot terminal on the fog light relay, bend it 90 degrees carefully. Run a tap to the driver's front corner parking light and connect this to the aforementioned bent out terminal. Had to drill a small hole in the fuse block case to accomodate the wire so that the locking cover would fit, but by far the simplest mod I've done yet.
