01-02 Tacomas......Are they the best ever?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SALEENSSC, Dec 4, 2008.
  1. Dec 4, 2008 at 8:48 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Naw Chris you know me when I heard you say my engine my ears shut off and you ought to have put a leash on me:D anyhow we 3.4s and 2.7s can still brag up what awsome engines these really are:)
  2. Dec 5, 2008 at 4:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    True!
  3. Dec 8, 2008 at 8:04 AM
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    Love mine. Bought a 2001 double cab and have a lot of people asking me If I wish I would have kept my 2005 fx4 4door. No, Nope and Hell no. That truck is just what I wanted and needed. I'm no mudder or rock crawler, but I hunt almost every weekend from 11-01 thru 02-28 and so far I like what I see. Toyota from now on. Rick
  4. Dec 8, 2008 at 2:20 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    03's are better :p
    Not being biased or anything...
  5. Dec 8, 2008 at 4:13 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    That is a beautiful Tacoma Rick:) we do not see the gold around these parts-so it really pops!
  6. Dec 8, 2008 at 5:01 PM
    kmrofka
    kmrofka Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    true that
  7. Jul 21, 2010 at 6:56 PM
    RockyTacoma
    RockyTacoma Well-Known Member
    Dojo
    colorado
    2002 tacoma trd
    stock
    Yes its true 01-02 are the best ever!!!!specially black 02 trd extra cab stepside.
  8. Jul 21, 2010 at 7:00 PM
    Madjik_Man
    Colorado Front Range
    I was about to chime in and pimp the '98s however the cup holder design is so retarded that I couldn't do it
  9. Jul 21, 2010 at 7:07 PM
    747
    747 function > form
    1st Gen.
    '03 owner here...is there any substantial difference btwn 01-02 and 03-04?
  10. Jul 21, 2010 at 7:19 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Well the 03 has... well umm it can... no. 01-04 are all basically identical.
  11. Jul 21, 2010 at 7:21 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If your talking dependability the mid 80's Toyota trucks were the best in my experiance.
  12. Jul 21, 2010 at 7:33 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    My 07 was not that great, my 04 is great but my 98 Taco was the best, 200k miles, went through hell and back, air time and no problems....
  13. Jul 21, 2010 at 7:44 PM
    04prerunner
    04prerunner Well-Known Member
    kyle
    tampa, Fl
    2004 prerunner
    stock
    dont forget my 2004
  14. Jul 21, 2010 at 9:53 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Drive by wire for 03-04, whereas 01-02 were cable
    also in 03 ABS came standard for most of em i think.
  15. Jul 21, 2010 at 9:55 PM
    #35
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow, old thread......
    Seriously,Toyota threw away the molds when they finished the '02 production run. :D
    '03s & '04s were cobbled together with left over '02 parts. :rolleyes: Seriously....
  16. Jul 21, 2010 at 9:56 PM
    #36
    747
    747 function > form
    1st Gen.
    Thanks. OP: "No; 03-04 are the best ever.":)
  17. Jul 21, 2010 at 9:58 PM
    #37
    747
    747 function > form
    1st Gen.
    *sigh* Oh Digirat; so wrong, sooo misguided.;)
  18. Jul 21, 2010 at 10:01 PM
    #38
    pittim
    Pennsyltucky
    Boujee Prius
    Nah, in 03 they perfected the truck, so they started figuring out how to make the next generation truck worse than the current generation truck :p
  19. Jul 21, 2010 at 10:02 PM
    #39
    Digiratus
    Roaming the PNW
    The RedHead
    Really? Does that mean I am less green now? :pray:
  20. Jul 21, 2010 at 10:03 PM
    #40
    747
    747 function > form
    1st Gen.
    -1 coming at you.
