01-04 2wd fenders and bedside on 4wd?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sreppep, Jan 26, 2017.
  1. Jan 26, 2017 at 6:19 AM
    Sreppep
    Sreppep [OP] Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    Was just curious if anyone has put the 2.4 5lug fenders/bedside on their 6lug 4x4?
  2. Jan 26, 2017 at 6:21 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I am pretty sure the body panels are the same across 2wd and 4wd trucks..
  3. Jan 26, 2017 at 6:41 AM
    Sreppep
    Philip
    Fort Worth, TX
    Yea I'm pretty sure they are they same too, I was just wanting to see pictures if someone had done it.
  4. Jan 26, 2017 at 9:04 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I have a prerunner 01
    Are 4wd bedside different ?
  5. Jan 26, 2017 at 10:32 AM
    Sreppep
    Philip
    Fort Worth, TX
    i meant 2.4 5lug 2wd**
  6. Jan 26, 2017 at 2:12 PM
    CaliTaco007
    CaliTaco007 Well-Known Member
    01-04 they all use the same fender flare. If im not mistake pre-2001 models have the smaller fender flare
    PROseur likes this.
  7. Jan 26, 2017 at 3:12 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    mjbtaco[QUOTED] likes this.
  8. Jan 26, 2017 at 5:20 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    95-00 5 lug 2wd fenders are different than any prerunner/4wd fenders. 95-00 prerunner/4wd may be different than 01-04 cuz the corner lights are different. 01-04 2wd 5 lug/prerunner/4wd fenders are all the same.
  9. Jan 26, 2017 at 5:36 PM
    Sreppep
    Philip
    Fort Worth, TX
    I know the lights etc are different on the older tacos, I was just wondering if the 01-04 5lug 2wd fenders and bed will fit my 01 4x4 so I can get rid of the fender flares. Wasn't sure if there is a difference between them other than the fender flare itself.
  10. Jan 26, 2017 at 6:04 PM
    mjbtaco
    Michael
    Montclair , so cal
    As long as its not a double cab the bed will work. The bed on any 5 lug will be longer than a double cab. Fenders will work too.
