01-04 Cruise Control?
Discussion in '4 Cylinder' started by PhilC, Aug 10, 2009.
  1. Aug 10, 2009 at 2:31 PM
    PhilC
    PhilC [OP] Member
    Phil
    Indianapolis, IN
    06 Tacoma TRD Sport
    I have checked at 3 different dealers, and can not find an OEM cruise control does anyone have any suggestions on how to find the how system?
  2. Aug 10, 2009 at 3:40 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    The cruise control mod is based on 2005+ models . the throttle has no cable, its done by electronics..wire. I dont honestly know how to go about doing your model, but it would inolve more components like vacuum lines(i think), adding fastening points and running/splicing wires.
    I think you can add C.C. , bt it will be 3x or more in labor and parts. Talk to the peeps on gen 1 part of the forum, they could give you more precise info i think.
  3. Aug 10, 2009 at 4:43 PM
    PhilC
    PhilC [OP] Member
    Phil
    Indianapolis, IN
    06 Tacoma TRD Sport
    I will check with them, thanks
