01-04 DIY Retrofit Help
Discussion in 'Lighting' started by pupdrew, Mar 5, 2017.
  1. Mar 5, 2017 at 8:23 PM
    pupdrew
    pupdrew [OP] Well-Known Member
    Andrew
    805 SLO- 951 Riverside
    04 4x4 Dbl Cab TRD
    working on it!
    So i have my mind set on building my own set of retrofit lights, but i don't even know where to start. I'm going to be buying everything from the retrofit source, but i don't know what will fit and what wont fit. I'm going for blacked out housing, color changing halos and demon eyes. High beam and low beam. So if anyone who has built or know about this subject can throw out some ideas or tips that would be great. Also I'm sorry if there's a post about this, Ive been looking into this since i picked up my truck but still couldn't find the right posts to help me out.
    What I know already:
    - Morimoto D2s
    - 35w Ballast
    - Motocontrol H4/9003 Harness
    - 5500k Bulbs
    Id appreciate all the help on which products to add to my cart. Also ideas/ suggestions are appreciated. Pics would help too! thanks
  2. Mar 5, 2017 at 8:24 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    @TRSAndrew
    This member works for TRS and is extremely knowledgeable. He can help you with the exact parts you need.
    pupdrew[OP] likes this.
  3. Mar 5, 2017 at 8:27 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  4. Mar 5, 2017 at 8:38 PM
    snowbrdd
    snowbrdd Well-Known Member
    Keep in mind that having colors other than white or amber on the front of your car is illegal, though it is up to the discretion of the cop whether they pull you over or not. My brother has gotten pulled over at least 4 times in 4 years with his color changing halos.
    To black out the housings yourself, I would use black plastidip. Use some glossifier if you want a shiny black rather than matte black.
    For halos and demon eyes, you have a choice between Morimoto and Diode Dynamics. Lightwerkz has several Youtube videos comparing the two companies, so you can watch those to make a choice. I feel that Diode Dynamics has the superior switchback option for halos, but both are almost equivalent as far as RGB is concerned. I would buy a couple of add-a-fuse to run power for your halos and demon eyes.
  5. Mar 5, 2017 at 8:46 PM
    pupdrew
    Andrew
    04 4x4 Dbl Cab TRD
    working on it!
    do you have pics of your brothers set up?
  6. Mar 5, 2017 at 10:25 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    I'm not really sure you wanna use plastidip to paint your internals.. I'm guessing, but I'd imagine it would outgas. Maybe not. I'm not sure. But that sounds kinda iffy to me. I would say high temp paint. It gets hot in there...
    DustStorm4x4 and Ariyan like this.
