01 2.4L Major problem
Discussion in 'Technical Chat' started by antwan718, Apr 7, 2010.
  1. Apr 7, 2010 at 12:22 PM
    antwan718
    antwan718 [OP] Member
    FL
    01 2.4L Taco
    Hello everyone, I am here for some advice.
    My mom has had her Tacoma for about 6 months now, and she has been getting 13 MPG. Its stock, no lift I assume stock tires.
    She has been having poor MPG since she got it there are only 50k miles on the truck. We put a set of new Good Year's on it and I threw some synth oil in there and sprayed carb cleaner through the throttle body to clean any gunk out of there. And the air filter is brand new.
    SO a month later we are still getting 13 mpg.
    Today I am taking the truck to the local Autozone to do an OBD2 scan, the check engine light is not on but I figure the computer may store soft codes.
    Will the Computer pickup a bad 02 or Mass air Sensor or do those need to be checked another way?
    I am used to working with my diesel ram not on a gasser (never touched a gasser)
    I am planning on changing the spark plugs on the thing, does anyone know the gap settings needed. And at 50 thousand miles would it be worth it to replace the cables for the spark plugs?
    Any advice is helpful thanks.
  2. Apr 7, 2010 at 12:22 PM
    antwan718
    FL
    01 2.4L Taco
    forgot to subscribe thanks.
  3. Apr 7, 2010 at 12:34 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Plugs, stat!!
    Gap 0.032
  4. Apr 7, 2010 at 12:35 PM
    btkicker
    Denver
    Skip the wires. But whatever, it won't hurt.
  5. Apr 7, 2010 at 12:45 PM
    antwan718
    FL
    01 2.4L Taco
    I remember my dad saying stuff about spark plugs being damaged indicating things, what would be the ideal conditions for the plugs to come out looking like?
  6. Apr 7, 2010 at 2:44 PM
    antwan718
    FL
    01 2.4L Taco
    Ok so i got back from the parts store and its throwing
    P0300 Misfire
    P0100 MAF or VAF Malfunction
    P0110 IAT Sensor Circut
    P0125 Closed loop Fuel Ctrl
    P1135 Manufacturer control fuel air meter
    P0171 System to lean
    P1130 Manufacturer control fuel air meter
    Does this look like an electrical problem, or just one problem Setting off a bunch of others?
  7. Apr 7, 2010 at 2:47 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    ...I wonder what your air filter looks like.
  8. Apr 7, 2010 at 2:51 PM
    antwan718
    FL
    01 2.4L Taco
    was replaced less than 30 days ago
  9. Apr 7, 2010 at 2:56 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    OH I see this in the post now- do you think it's possible that some sort of leaves or other restriction might have entered the air intake manifold? I'm going to back off now before I make myself sound like an idiot. :D
  10. Apr 7, 2010 at 2:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    clean your maf sensor and replace the fuel filter and see what happens.
  11. Apr 7, 2010 at 8:29 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    X2 on cleaning the MAF sensor. Remember to only use an MAF cleaner, CRC makes a spray specifically for that.
