01 4 door 1 ton SAS
Discussion in '1st Gen. Builds (1995-2004)' started by thegame, Apr 13, 2014.
  1. Apr 23, 2014 at 8:13 PM
    #41
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    wishing I had the skills to do this, looks great
  2. Apr 23, 2014 at 10:55 PM
    #42
    thegame
    thegame [OP] Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    The old ARB locker I had? It sold and I gave the complete stock rear axle to my buddy who is going to put it in his 83 Toyota.
    Thanks for the compliments! I edited all the posts because everyone likes big pictures :D
  3. Apr 23, 2014 at 11:05 PM
    #43
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Subbed, because this thing is awesome.
    Also I am interested in the front stock CV axles if you are selling.
  4. Apr 23, 2014 at 11:41 PM
    #44
    el topu
    el topu Well-Known Member
    Juan
    SLC, Ut
    Tundra Limited CM TRD Off-road
    Looks great!! keep the info coming
  5. Apr 23, 2014 at 11:42 PM
    #45
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I am giving priority to a friend of mine who wants to buy all my old IFS stuff. If he doesn't follow through, next priority goes to locals.
    Didn't get too much done today. I chopped out the rear crossmember that holds the stock spare tire winch and replaced it with a piece of 1.5"x.250 DOM to hold my shocks. Got one mounted so far. U bolts and u bolt plates are being painted.
  6. Apr 24, 2014 at 12:19 AM
    #46
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    The rear suspension is temporary. I plan to link it with coilovers, like the front once I get all the bugs worked out.
  7. Apr 24, 2014 at 10:18 PM
    #47
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Got some more work done today. Tidied up the rear shocks, just need to fully weld them when I can flex the truck out to make sure the location will work. Link brackets showed up, pieces of art work! Shoved the D60 at full bump and started throwing links at it. The brackets made quick work of about 3 days of work, VERY happy with them! By the numbers, I should be getting around 6 or 7" of straight up travel which I'm happy with. I really don't have much room for the axle, where it's sitting now, its about 1/4" from the oil pan. If I move the axle more forward, I have about 1/2" before the heim at the pitman arm contacts the tie rod. I like where it's sitting though, once I start looking at where the panhard can go, I may move the axle just a little bit more forward if I need to. The goal is to have a straight panhard, not bent.
    Tomorrow will be spent fitting up brackets to weld onto the cast D60 center section. I cut one out and need to drill a hole in it. Got the torch ready for welding :D
  8. Apr 24, 2014 at 10:20 PM
    #48
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the angles on these things make my mind hurt, but look fucking awesome
  9. Apr 24, 2014 at 10:57 PM
    #49
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Not nice on the wallet but I can't even begin to explain how well they were designed. My exhaust fits perfect and the upper on the driver side gets real close to the fuel lines but doesn't touch. Doesn't touch the transfer case. Excellent pieces of metal! If Brian had a kit for this truck and this axle, I would be all over it. He's supposedly working on it now :cool:
  10. Apr 26, 2014 at 11:10 AM
    #50
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Got my welds looking similar to Brian's at 4WU :cool:
    SilverGhost likes this.
  11. Apr 26, 2014 at 11:49 AM
    #51
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  12. Apr 26, 2014 at 1:16 PM
    #52
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Wow sub'd for this
  13. Apr 26, 2014 at 1:22 PM
    #53
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    Welp when u are done sell me the truck too
  14. Apr 26, 2014 at 8:04 PM
    #54
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Them welds!!! Stacking dimes!
  15. Apr 26, 2014 at 9:50 PM
    #55
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Welded tabs directly to the tie rod for the drag link. I feel like it needs more metal added to it though. I wanted to keep as much misalignment as I could which meant bending the tabs to get it welded to the tie rod. Cranked the welder up full tilt and burned it on. I decided to weld tabs straight onto the tie rod after I put tabs on the adjustable OD clamp. It looked too busy with the OD clamp on so I set the toe again and will run with it. Should be ok, I think.
    I hope to get the frame end panhard mount done tomorrow so I can flex her out and see what hits Then next weekend I'll be mounting coilovers and potentially air bumps.
    And I was able to squeeze 9" of vertical separation at the axle with the big upper link mount. Pretty happy with how that came out, still need to fully weld it with the special wire for welding to cast iron.
  16. Apr 27, 2014 at 5:10 PM
    #56
    taco52
    taco52 Well-Known Member
    01 SR5 v6 5speed 4x4
    This build is awesome so far. Keep it up
  17. Apr 27, 2014 at 5:24 PM
    #57
    Large
    Large Red
    Excellent work :drool:
  18. Apr 27, 2014 at 5:30 PM
    #58
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    This is glorious! Can't wait to watch this through!
    Amazing work OP!!!
  19. Apr 27, 2014 at 10:29 PM
    #59
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Knocked out the panhard today first thing, got it tacked in by noon and flexed the axle out. Shit hits everywhere at full tilt but I'm thinking the shocks will keep it from going too far, maybe. Slapped tires back on and trimmed the fenders out. I really hate most all rear fender trims and mine is no exception. It looks like hell and kinda wish I didn't cut so much but whatever. The tires will never hit :rolleyes:
  20. Apr 27, 2014 at 11:09 PM
    #60
    DoccoM85
    DoccoM85 Well-Known Member
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Your Beer Koozie is awesome!
    ....................Truck too
