01 First Gen TRD Wheel Offset
Discussion in 'Wheels & Tires' started by ceepow134, Aug 24, 2021.
  1. Aug 24, 2021 at 10:21 AM
    ceepow134
    ceepow134 [OP] New Member
    Looking to replace wheels and trying to understand how much a 10mm negative offset will affect things.
    From what I can tell, the OEM wheels I have on now are 16x7 6x139.7 with 15mm offset.
    The wheels I'm looking at are 16x7 6x139.7 with 5mm offset.
    I've read you should try to keep offset within 5mm of originals, but is a 10mm difference enough to cause rubbing or any other negative side effects? Thanks
