01 ford expedition rear end
Discussion in 'General Automotive' started by mnudo200827, Oct 2, 2012.
  1. Oct 2, 2012 at 9:51 PM
    mnudo200827
    mnudo200827 [OP] Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    My parents expedition had a whine from the rear end for a short time and now some of the teeth off of the ring and pinion broke. im guessing its a pinion bearing that was bad because my dad changed the outer axle bearings and that didnt fix it. The tag on the differential says S802L and 31 88 ok12. I looked it up online and it says its a 8.8" ring gear and 3.31 ratio. Is that correct? I told them just to swap out the whole rear end from a junkyard one so they dont have to figure out why it broke. But my question is, would a different ratio make a difference? Just as long as its close to the same ratio it should be okay right? its just a 2wd too, so dont need to match gears. Thanks..Mike
  2. Oct 2, 2012 at 9:53 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    Different rear end will change a few things but nothing drastic if the rear end is coming out of another expedition. Bottom line is it will work fine if its out of the same model.
  3. Oct 2, 2012 at 9:59 PM
    mnudo200827
    Michael
    Corona, CA
    yeah was going to get it out of another expedition.
  4. Oct 2, 2012 at 10:01 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Should be fine
  5. Oct 2, 2012 at 10:13 PM
    mnudo200827
    Michael
    Corona, CA
    just asking just incase we cant find the exact same one.
  6. Oct 2, 2012 at 10:15 PM
    TACOMABOSS
    96 SR5 4x4
    since its 2wd the gear ratio wouldnt matter. If i am correct it wouldnt hurt anything, but the same ratio you have in it would be best because that what it came with from the factory. I dont know if they had different ratios in those for different years
  7. Oct 2, 2012 at 10:24 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
