01 headlamps - OEM replacement brand help
Discussion in 'Lighting' started by Beach Beagles, Oct 25, 2014.
  1. Oct 25, 2014 at 6:24 AM
    Beach Beagles
    Beach Beagles [OP] Member
    Tim
    Virginia
    01 Black D-Cab PreRunner SR5
    Line-X bedliner, 3"black nerf bars
    I have an 01 with foggy headlamps and have done the restoration which works for a while. Are the aftermarket lights as good as buying Toyota OEM parts? If the aftermarket brands are good which brand and vendor do you suggest? I don't want to waste my money on junk. Thanks
  2. Oct 25, 2014 at 6:30 AM
    BamaToy1997
    Bill
    Navarre, FL
    I sell aftermarket lights to my customers all the time, and we have bought them for family vehicles. Have never had a SINGLE complaint or issue with them. What I would suggest is make sure that they do state DOT approved, and that you just do a lit of research before you buy them. I spend anywhere from $70 a pair up to $175 a pair, depending on the vehicle.
  3. Oct 25, 2014 at 7:02 AM
    scocar
    scocar Patron of the Farts
    I've been looking into this too.
    I've seen some people complain about poor dispersion pattern on some aftermarket brands. I seem to recall some folks being dissatisfied with Anzo, and perhaps some others, but not sure of specific without more research.
    You will notice that vendors like Rock Auto may have a couple different brands, or say you may get a different one depending on what they have in stock. I'd be picky and careful about this.
    Bill, what brands have you used?
  4. Oct 25, 2014 at 9:00 PM
    BamaToy1997
    Bill
    Navarre, FL
    I usually stick with "Eagle Eye" brand.
  5. Oct 27, 2014 at 5:07 AM
    Beach Beagles
    Tim
    Virginia
    Thanks for the info.
  6. Oct 27, 2014 at 5:15 PM
    Beach Beagles
    Tim
    Virginia
    Is Depo brand any good?
    Update:
    A local place (Hylinks) sells the Depo brand. I got them for $45.00 each (Assembly with bulb) and they were easy to install.
