01 Prerunner Trans. service
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigbyrd527, Mar 9, 2011.
  1. Mar 9, 2011 at 6:21 AM
    bigbyrd527
    bigbyrd527 [OP] New Member
    Robert
    Panama City Florida
    01 Prerunner
    When talking to a friend recently about my Prerunner transmission service, he said to just "drain and fill" a couple of times instead of the usual remove pan, clean or replace filter and refill.
    I think "several" second opinions are needed to convince me that is the proper method.
    Also, need fluid recomendations, and how much I need to have on hand.
  2. Mar 9, 2011 at 8:21 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    personally id sooner drop the pan. alot of shit can settle on the pan that you actually need to wipe off. i dont have an automatic but id say droping the pan would also be the cheaper route.
  3. Mar 9, 2011 at 7:34 PM
    ChavisT93
    ChavisT93 Well-Known Member
    Lexington, SC
    07 reg cab base
    Just drain and fill. There is no filter, only a screen. The screen does not need to be serviced. If your trans fluid hasnt been regularly changed just do 3-4 drain and fills with a short trip between each. This will get most of the old fluid out.
