'01 Taco DC: Fuse Box. Relay Box and Circuit Breaker
Discussion in '1st Gen. Tacomas (1995-2004)' started by TejasYOTA, Feb 9, 2013.
  1. Feb 9, 2013 at 1:09 PM
    TejasYOTA
    TejasYOTA [OP] Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    Just finished installing my BlueSea SafetyHUB 150 Fuse Box, a Hella Relay Box and a BlueSea Circuit Breaker@100amps.
    Most of the items were bought from Amazon or Del-City.
    Not my pic of the Hella Relay Box
    BlueSea SafetyHUB 150 Fuse box
    2-gage bulk battery cable
    1/0-ga terminated battery cable
    Solder slugs and lugs
    I originally tried to use the Blue Sea 5026 fuse box.
    But unfortunately I had no real room to mount it where I wanted.
    So after I remeasured and searched I bought the BlueSea SafetyHUB 150.
    After spending a good amount of time looking for a piece of scrap metal to mount everything... I was able to dry mount everything to see how it would look.
    Terminated some pig tails for the relay box
    Made some battery cables
    Plug and play and I'm done.
    So now what.....i will get myself a battery box to replace that factory hold down and the plastic tray under the battery.
    But that will be later on.
    I will do a better write up on TTORA later on.... but for now I want to hang and toss back a brew. :)
    Forgot to mention that this is mounted ONTOP of the factory fuse box.
  2. Feb 9, 2013 at 10:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Nice clean work brother. I good reminder for me, I really need to sort out the spaghetti mess at my positive post on my battery.
    I've never seen those green solder slugs before. How to those work?
  3. Feb 10, 2013 at 5:04 AM
    TejasYOTA
    Nathan
    Country of TEXAS!
    The Solder Slugs are SO SIMPLE... as long as you are not afraid of fire :)
    They are premeasured solder and flux.
    So knowing what gage you are soldering is important.... it's color coded.
    Here is a vid on it.
    http://www.youtube.com/watch?v=SXDkNMDDrBs
    Ihnaer likes this.
  4. Feb 10, 2013 at 9:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Good info. Learned something new. Thanks Man.
  5. Feb 24, 2013 at 5:12 AM
    TejasYOTA
    Nathan
    Country of TEXAS!
    FYI - - for the continued course of 5-s; i bought more stuff.... :)
    Battery Terminal Boots that will fit a Military Clamps
    I bought the oval, because of the two cables running off the positive side.
    Bus-Bar for my non-critical power feeds - LED rock lights, Hood light, etc.
    I bought the 20 connecter version that uses push-on tabs for under the hood and a 10 connector version for the inside (Stereo receiver, CB, radar, etc.).
    All were from VTE Warehouse.
    https://www.vtewarehouse.com/index.php
    Note there is a $15 minimum order and the prices are really good for those bus-bars.
  6. Feb 24, 2013 at 5:56 AM
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
    cool learned some thing new. Subed for later use :popcorn:
  7. Feb 24, 2013 at 7:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I looked at that hella relay box. Does it come with those clips? Just take standard relays??
    Might get one to clean up my engine bay relays. I'm using a bussman in the rear for my other lights.
    I like the safety hub better too over the fuse box..
  8. Feb 26, 2013 at 4:03 PM
    TejasYOTA
    Nathan
    Country of TEXAS!
    The clips comes with the Relay box. (BONUS!)
    Incase you are wondering how I mounted the stuff..
    Made a cardboard template.
    Had braces from an old engineering project and used them.
    Just happen to be the right size for this.
  9. Feb 26, 2013 at 4:09 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Looks good.
  10. Feb 26, 2013 at 4:22 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Very cool.
  11. Feb 26, 2013 at 4:31 PM
    scocar
    scocar hypotenoper
    Subbing the hell out of this. Finally, some great pics and setup on an 01! Beautiful work :thumbsup:I
    I've just started to research a bit of this for trailer hitch wiring and a new stereo setup, but I want future exapandability too.
  12. Feb 26, 2013 at 4:42 PM
    scocar
    scocar hypotenoper
    What method did you use to secure the metal plate to the top of the OEM fuse box? Drill holes through the stock fuse box cover and use bolts from the inside of the cover to those metal U brackets, and nuts on the outside? Can't quite tell from the pix.
  13. Mar 3, 2013 at 7:12 AM
    TejasYOTA
    Nathan
    Country of TEXAS!
    nuts bolts through the factory fuse box cover and those brackets.
    I also did some more work... the bussbar, military terminal boot-isolator arrived and I mounted my hood light.
    The bussbar will be installed next weekend... spent the majority of this weekend on taxes... oh yeah....
    VTE Bussbar at the location I plan to mount.
    The wires from my LED Rock lights that will be terminated there.
    Military Terminal boot-isolator cover mounted... no more shorts... i hope. :)
    Cut a slit at one end and zip tied it to the terminal.
    Loose enough to slip off to do work if needed.
    Under the hood light.. used the same brackets I bought for my LED Lights.
    Wiring
    Plunger switch to activate the light... existing hole.
    Had to remove paint to the raw metal and then used dielectric grease to ensure it grounds well and lesser chance of rust forming there.
  14. Mar 3, 2013 at 7:13 AM
    TejasYOTA
    Nathan
    Country of TEXAS!
    thanks... check out my Garage posts on TTORA... it has more detail of all my mods (except this - - one i am done with my taxes I will do a formal write up.
  15. Mar 3, 2013 at 8:44 AM
    scocar
    scocar hypotenoper
    Yeah, thanks, I already went and looked at your TTORA writeup so far. Very nice.
  16. Mar 21, 2013 at 1:26 PM
    TejasYOTA
    Nathan
    Country of TEXAS!
    Now I can say I am TOTALLY DONE with my electrical stuff.
    Today I installed my VTE Bus Bar.
    VTE Bus Bar mounted
    VTE Bus Bar uncovered and hooked up.
    VTE Bus Bar covered
    Check out my Garage Section for the install
