01 Taco Power Window issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Si-Rick-Yu, Oct 17, 2023.
  1. Oct 17, 2023 at 4:35 PM
    Si-Rick-Yu
    Si-Rick-Yu [OP] New Member
    Richard
    2001 Tacoma Flair side
    None
    Windows can't roll down or up. Changed the switch on both the driver and passenger door. checked the child lock button. The only time that it worked was when I connected the window motor directly to the battery. would be interested in any links you may have in getting to the bottom of this.
    Thank you
  2. Oct 18, 2023 at 7:12 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Fuse or Relay?
    Anything else that doesn’t work?
    You or anyone worked on truck before P/W’s stopped working?
  3. Oct 18, 2023 at 7:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked your Power fuse (30A) in the interior fuse box?
    If that's good have you checked for power at your window switches on the Blue/Red wire and ground at the master switch on the White/Black wire?
  4. Oct 18, 2023 at 9:26 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I had an issue on my truck when I first bought it. All windows would work expect the rear drivers side. I replaced everything I could think of, and nothing. I started chasing the wires with a multimeter and I found, strangely enough, that the plug under the driver's side kick panel I believe was just loose enough to cause the one window not to work. I unplugged it and clicked it all the way in and it worked without issue.
    ControlCar likes this.
  5. Oct 23, 2023 at 10:03 PM
    Si-Rick-Yu
    Richard
    None
    First off thank you all for your response. I've checked all the fuses. I tested all the relays because I'm not sure where the power window relay is located. Took the driver's side door apart and tested the window motor directly to the battery. Replaced both driver and passenger side switches. I looked at the wire harness on the driver's side. This all started when I left for a month for my daughter's wedding last year:). I came home, and the windows stopped working. I live on an island; the heat and humidity are hardcore year-round. Any ideas and possible solutions are extremely and profoundly appreciated.
