01 tacoma 2.7
Discussion in 'Solid Axle Suspension' started by Newbiegeneral, Aug 14, 2013.
  1. Aug 14, 2013 at 7:50 AM
    Newbiegeneral
    Newbiegeneral [OP] 01 taco
    randon
    shamokin pa
    Blacked out reg cab 2.7 taco
    Kc lights and sliders! More to come
    Alright i have a base taco, and plan on getting a lifted jeep xj that needs a tranny. However is it possible to swap the jeep axles and wheels over to the taco? Can anyone help me with this?
  2. Aug 14, 2013 at 7:52 AM
    Newbiegeneral
    randon
    shamokin pa
    I should say what will it taketo put the jeep axles under my yota, simple just cut it off the jeep and weld it on to my yota with minor modsto work correct?
  3. Aug 14, 2013 at 7:06 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    It's a long process man. Follow this link and do some research. It's alot more work than just cutting off your jeep and welding it to the toyota... haha
  4. Aug 14, 2013 at 7:10 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    If it were that easy then you would see more solid axle Toyotas
  5. Aug 15, 2013 at 11:49 AM
    Newbiegeneral
    randon
    shamokin pa
    Actually found a thread where a guy did it, took jeep axles and what not and put them in a yota. Having this done at shop. Did a tonof research and see dana 60 or waggy 44's nothing like stock cherokee axles for weekend warrior stuff nothing insane right now
  6. Aug 15, 2013 at 2:47 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    If all you're doing is weekend warrior stuff, keep the Taco like it is. No sense wasting all that effort for such little gain.
  7. Aug 16, 2013 at 1:58 PM
    Newbiegeneral
    randon
    shamokin pa
    Well i take it places id rather have it straight axled, my question is, tacoma on dana 30 and 35 with 35's and not being throttle happy how will she hold up
  8. Aug 16, 2013 at 11:58 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    :facepalm:
    Leave the jeep axles where they belong... under the Jeep.
  9. Aug 17, 2013 at 5:16 AM
    Newbiegeneral
    randon
    shamokin pa
    I am found a ram 1500 gonna go that route
  10. Aug 18, 2013 at 1:23 PM
    Supra TT
    Eric
    Indiana
    So you're using an older ram now instead of the toyota? Or putting jeep axles under the ram, which is it :D
  11. Aug 18, 2013 at 2:51 PM
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Probably bought the Ram 1500 thinking it would be a better wheeler since it has a solid axle STOCK! When in reality they don't make a good wheeler :rolleyes:
  12. Aug 18, 2013 at 8:53 PM
    SoCalXD
    SoCalXD Member
    Adam
    San Diego
    TBD: Here to learn about the Taco
    People due the craziest things!
  13. Aug 22, 2013 at 9:34 AM
    Newbiegeneral
    randon
    shamokin pa
    Haha no the ram has 44s im planning on stealing those out of it. Then taking my time to collect parts. Would a cj dana 44 go right under without needing shortened?
  14. Aug 25, 2013 at 12:06 PM
    Supra TT
    Eric
    Indiana
    I thought you had ram axles for it! CJ's came with Dana 30s...
  15. Aug 29, 2013 at 7:33 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Yes possible but why would you want a d30/5 not sure what they have In the front but its weak. Look for a waggy 44. The rear 8.25 is far weaker than your 8" 3rd member. I just got my axles from a D250 Dana 60 F&R geared to 5:88.
  16. Apr 7, 2014 at 4:42 PM
    Newbiegeneral
    randon
    shamokin pa
    Okay picking up a dana 44 waggy. Flat knuckling it with hysteer. 4:10's and new joints. Then installing shackles and some chevy leafs upfront for starters to see where it will stand. From there doing the ifs steering and possibly hydro assist as well.
    What shackle brackets and front crossmember would you go with or just fab my own cross member for the front?
  17. Apr 8, 2014 at 4:57 PM
    Newbiegeneral
    randon
    shamokin pa
    Decided on sky offroad front member and shackles and mounts plus the hoops. So at about 4-500 for brackets. Need to see if 63 chevys will give me 3-4 inches. Then rebuilding the 44 new spicers, gears and unsure of what to due with knuckles for highsteer? And clocking it( how many degrees.
