'01 Tacoma 345,000 coil issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ofrog, Apr 25, 2023.
  1. Apr 25, 2023 at 6:56 AM
    Ofrog
    Ofrog [OP] Member
    Florida
    01 PreRunner
    I have been experiencing a bump, almost like someone hits my bumper at 60-65 MPH. Intermittently. Doesn't always happen. I changed the spark plugs & replaced the wires NPK package. In doing so I noticed a bit of corrosion on aone of the coils which I cleaned off. (Corrosion outside maybe equals corrosion inside?) I don't throw a code and other wise truck runs fine at all speeds. I don't want to replace a $150 part for no reason. Is there a way to test a coil independently? Haven't found any posts or You tube specifically on this problem. In direction to remove this issue would be appreciated.
    1997tacomav6 likes this.
  2. Apr 25, 2023 at 7:59 AM
    1997tacomav6
    Denver
    Coils don't throw codes, camshaft and crankshaft do.
    My coils went south around that same miles
  3. Apr 25, 2023 at 8:13 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    The FSM outlines a method for checking resistance of the coils using a multimeter. If no one else responds before I get home today, I can post pictures of that section of the FSM. That being said if those are original coil packs, might be fair to assume they're worth replacing at this juncture anyhoo.
  4. Apr 25, 2023 at 8:45 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    ... If you're feeling a physical "bump" on your bumper... I'd be looking more towards driveline issues rather than motor related issues. Think U joints, carrier bearing, Leaf springs (and eye bushings), and shocks...
  5. Apr 25, 2023 at 11:13 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    If he is talking about ignition coils it could. But it wouldn’t help to move them around if it’s not throwing a misfire code. How many miles are on them? What engine?
