01 Tacoma 4x4 fuel filter help
Discussion in '1st Gen. Tacomas (1995-2004)' started by ZanderD, Jul 24, 2010.
  1. Jul 24, 2010 at 6:30 PM
    ZanderD
    ZanderD [OP] New Member
    Alex
    IN
    my Tacoma regular cab 4cl has over 100k on it and i want to put a new fuel filter in it, i know they are supposedly lifetime fuel filters, but i still would like to replace it. but i am having a hard time figuring out how to get to the filter to replace it, the filter is but under the intake manifold and has banjo bolts on both side of it, can someone tell me how to replace it.
  2. Jul 24, 2010 at 7:09 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Not sure what that is. But the fuel filter in under the cab on the driverside. Little black canister.
  3. Jul 25, 2010 at 3:41 AM
    TallTacoma
    TallTacoma Bear fvcker!
    Charles
    The Silver State
    Come and take it from my cold, dead hands.
    3" suspension lift (ToyTec coilovers and wheeler leafs), Yakima roof rack, ARE tonneau, K&N FIPK.
    ^^^ Yes, it's under the vehicle mounted on the frame.
  4. Jul 25, 2010 at 8:01 AM
    ZanderD
    Alex
    IN
    im sorry for not mentioning this but i have a 2.7 4cl on a regular cab, for some reason the prerunners 6cl and tacomas with larger cabs have the fuel filter mounted under the driver. i know my fuel filter is under the intake manifold because the new filter i have has banjo bolt alignment pins on both sides of the filter,
    http://www.racepages.com/parts/fuel_filter/toyota/tacoma.html
    see the 6cl have the regular flare nuts but the 4cl has two banjo bolts
    has anyone dealt with this type of configuration
  5. Jul 25, 2010 at 8:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its tight, but can be done, if you have alot of patience.
    You can go at it from under the driver side fender, pull the fender liner, and you can access it there. Jack up the front, and remove the wheel for more room. Or, you can pull the intake runners. Pulling the intake runners is the easiest, but you have to remove more stuff.
  6. Jul 25, 2010 at 8:20 AM
    micropiper
    micropiper Admiral of the JOLLY ROGER navy
    damion
    phoenix az
    Four cylinders of pure awesome
    k&n air filter in a modded intake, sliders, new horn, plenty o pinstripes, custom onboard air,cobra cb with custom skidplate,
    Had the same problem with my 99. The front side can be accessed fairly easily. Go thru the fenderwell!!!!! Remove tire for workspace. Be patient they can b a huge pain to remove!!!
  7. Jul 26, 2010 at 12:16 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    also make sure you depressurize the system or you're going to have fuel spraying out at you
    when i change them, i usually diable the fuel pump (unplug it somehow, or pull a relay) start the car and let it die out
  8. Jul 26, 2010 at 1:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Pulling the "EFI" fuse will do this also.
  9. Jul 26, 2010 at 3:34 PM
    vantaco
    when you do that, does it also kill the ignition spark? if it does, then it won't work to depressurize the fuel system because the car won't fire and use the fuel
    if it does kill the sprak and fuel, that's what you would want for a compression test, you need to kill both the fuel and the spark, but still want it to be able to crank
  10. Jul 26, 2010 at 4:36 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    i just took my gas cap off to let depressurize. Better have some slinky fingers to get that sucker off. But don't fret, it can be done and you will be glad you done it when you see the trash that comes out of it when you get it off.
  11. Jul 26, 2010 at 5:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It will crank and not fire. Only take 1 or 2 revolutions do depressurize the system.
