01 Tacoma Factory Hitch
Discussion in 'Towing' started by subtleshift, Aug 31, 2010.
  1. Aug 31, 2010 at 8:45 PM
    subtleshift
    subtleshift [OP] Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
    Can anyone confirm the part numbers I need for a "Factory Tow package" on a 01 Tacoma?
    Ive been looking and it appears like their are 2 different part numbers for the wiring harness, I dont know the difference is between them and I have also heard about the different fan clutch that was equipped
    I know its cheaper to go aftermarket, but I want to keep it factory just to clear that up!
  2. Sep 3, 2010 at 8:50 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    Why do you want to go factory? Aftermarket and factory hitches are the same thing except the dealer will charge you twice as much. I bought a used Hidden Hitch for $75 and the wiring harness for $35. If you decide you want to buy a new hitch you can go to your local Uhaul or buy online from Etrailer.com. From etrailer.com the hitch will cost $145-$200 and the wiring harness will cost about $40. Use the 5% discount code, 98XL3. Etrailer has free shipping over $150.
    The hitch is easy to install with 4 bolts. You just need someone to give you a hand. The wiring harness is even easier. You can have both of them installed in less than an hour.
    http://www.etrailer.com/hitch-2001_Toyota_Tacoma.htm
    http://www.etrailer.com/Custom-Fit-Vehicle-Wiring/Toyota/Tacoma/2001/118379.html?vehicleid=20015562
  3. Sep 4, 2010 at 6:08 AM
    Barnone
    Barnone Guest
    ^^^^^+1
  4. Sep 20, 2010 at 10:24 PM
    Black Tacoma
    Black Tacoma Member
    Spfld MO
    01 Crew TRD
    I have an 01 w/ a hitch already in place. The wiring is a 4 flat but I need a 7 round. Does anybody make a 7 round adapter? I'm really looking for the switched 12v to charge my trailer battery.
    Grove
  5. Sep 20, 2010 at 10:26 PM
    Johnnie
    I.E. SoCal
    Feds
    You can find an adapter just at about any auto part store. Walmart might even carry them. They have a lot of towing supplies.
  6. Sep 21, 2010 at 7:58 PM
    Black Tacoma
    Black Tacoma Member
    Spfld MO
    01 Crew TRD
    But that won't have the brake controller or 12v power I'm looking for.
    Grove
  7. Sep 22, 2010 at 8:22 PM
    Johnnie
    I.E. SoCal
    Feds
    Then buy a brake controller.
  8. Oct 17, 2010 at 7:32 PM
    RedlegETT
    RedlegETT Member
    Las Cruces, New Mexico
    04 PreRunner Double Cab
    hey I am doing the same thing, try etrailer.com for the adapter that goes from the 4 flat to the 7 round connector. you still have to run the one battery wire and the blue from the brake controller. good luck
