01 tacoma front lift advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by bennett87, May 9, 2011.
  1. May 9, 2011 at 4:55 PM
    bennett87
    bennett87 [OP] Active Member
    Lee
    Jacksonville, NC
    01 Ext Cab SR5 Debadged
    debadged, Alpine sound system, bilstein 5100's upfront with OME 881s
    any other springs that would work well...whats the difference with OME and eibach??
  2. May 9, 2011 at 4:58 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The OME springs gome in other spring rates but you would need a top plate spacer to get a full 3" of lift.
  3. May 9, 2011 at 5:00 PM
    bennett87
    Lee
    Jacksonville, NC
    ill stick with the eibachs it just seems hard to find them anywhere for sale....
  4. May 9, 2011 at 5:39 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Aren't the ejbachs on national back order? And id really recommend some ome 881 coils and maybe a .5" top plate spacer.
    Cv boots will blow with 3" and a diff drop...ask me how I know. Unless your up for the nasty task of changing a boot it costs about 200 bucks to have it done for you. You could just keep buying cv axles every 8k miles but that's barely an improvement since they range from 50-80 and unless you were to install it you would end up running 250-280.
    I'm assuming everything here would be done by a shop of course so if you do it yourself that would help the cost but still, hoe much time do you really want to spend dicking around with cv's?
  5. May 9, 2011 at 6:03 PM
    bennett87
    Lee
    Jacksonville, NC
    well then would it be worth just getting 2" spacers and leaving stock springs and putting 5100's on it??? this is my daily driver that im just trying to make my tires not rub and look decent i dont want to be pouring money into CV's all the time especially if im not really taking it offroad that often
  6. May 9, 2011 at 6:25 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Maybe look into OME 881's with a small top plate spacer. Thats what I ended up doing since I didn't want to worry bout cv angles too much. I ordered from wheelers and got their 10mm spacer. I'm at almost 3" right now but it should settle to about 2.5", least that's what I'm hoping for.
  7. May 9, 2011 at 6:42 PM
    bennett87
    Lee
    Jacksonville, NC
    did u run the 881s with new struts or did you just keep the stock ones?
  8. May 9, 2011 at 6:57 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    OME Nitrocharger shocks...the billie 5100's are cheaper tho but I figured I'd match OME with OME for supposed matched valving.
  9. May 9, 2011 at 6:58 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    damn you. :mad:
  10. May 9, 2011 at 7:01 PM
    RPain
    Chandler, Arizona
    if you don't want to bother with worrying about the cv's just buy some bilsteins and set them at the 2.5 in setting. cheap and ride just fine
  11. Jun 21, 2011 at 7:14 PM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    I have a warn 8000# winch with steel cable and ARB - would I be okay with the 881's and OME shocks up front?
    I specify OME since that is what i JUST installed in the rear - shocks and spring packs.
  12. Jun 21, 2011 at 11:08 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    People will suggest the 882 coils since you have a double cab w/ a V6.
    On a side note, you're profile says you have Sway-A-Way C/O's. Any reason you're switching to OME's?
  13. Jun 22, 2011 at 7:01 AM
    bowyer2002
    NE Missouri
    I think I just want OME shocks and springs all the way around.
    I will take off the C/O's, replace the oil and sell them - they work fine, just thinking that if I have a matched suspension it may ride better.
    I do little off-roading except for hunting, camping & driving around the farm - so the C/O may be overkill.
  14. Jun 22, 2011 at 7:31 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    Yeah that was kinda my deciding factor on whether I should get OME or adj. C/O's. I decided on the 881 and Nitrochargers because they seemed the most practical for the type of off-roading I do.
    If you decided to get the OME stuff talk to the guys at DownSouth Motorsports. Good prices and free shipping.
  15. Jun 22, 2011 at 11:02 PM
    #35
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I dont recall seeing if the OP's truck is 4x or a prerunner, which of course changes things pretty dramatically, if 4x all the info I've gotten if you go with the Eibachs w/5100's in front (set at 0) you'll get 3" from the coils & as far as increased CV angle, you'll have an increase but here is where it gets a little fuzzy, I've seen some with 3" & not much change in angle & I've seen others that look like they'll rip apart as soon as you hit the dirt so I dunno... If 2wd then you have alot more options I'd think without all the issues you might have with IFS 4x4...;)
  16. Jul 15, 2011 at 9:10 PM
    #36
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    grave digger and thread jack. question: i got 881 and 5100 now, giving me 2.5 of lifts cuz i have 4 banger. i want 3'' lift, if i am going eibach, i will be over 3" which can cause more boots torn. i don't want to adjust my 5100 to the 2.5, i want to keep it at 0 to not preloading the 5100 too much. should i just get the 1/2 spacer to get the 3"? future plans will be runnig 33s and a tube bumper. suggestions and ideas?
