01 Tacoma ignition coil circuit problems
Discussion in 'Technical Chat' started by Curt9981, Mar 16, 2016.
  1. Mar 16, 2016 at 5:39 AM
    Curt9981
    Curt9981 [OP] New Member
    2001 Tacoma 3.4 liter V6
    What's up guys. I changed my drive belts a week ago an when I went crank my truck it would turn over fire for a few seconds then die. I changed crankshaft position sensor still no luck. My code reader is giving me a p1300 which is ignition coil primary feedback circuit. I've checked ohms on the main coil bank an they are good. Any ideas on what I can do next!?
  2. Mar 20, 2016 at 9:40 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    P1300 is for an "igniter" circuit. Not the same part as an ignition coil. It's the little flat box with a 10 wire flat connector. Found behind your air box, bolted to the fender well. So troubleshoot there.
    On 1st gens they are known for needing a good ground and for the connector pins individually working/wiggling their way out/loose.
    Red arrow below.
