01 tacoma smoking REALLY bad on start up
Discussion in '1st Gen. Tacomas (1995-2004)' started by ebayollis, Jun 21, 2015.
  1. Jun 21, 2015 at 3:37 PM
    ebayollis
    ebayollis [OP] MY DIXIE WRECKED
    josh
    spruce pine nc
    2017 tacoma trd sport ddbl cab 4wd auto
    With white smoke and runs extremely rough...I changed out the MAF sensor after reading a few guys had same problem... still does it. Once the truck is warmed up...say 7 minutes tops, it runs fine...I changed out my plugs wires and coil packs about 3 moths ago. . This has been happening for about a month now... it isn't using any oil...I'm truly getting fed up with it. Truck has 209,000 miles is it wore out?!? It isn't throwing any codes but I had it scanned anyway and it's showing a p0300 which I think is random misfires?? I've cleaned the air filter. ... I had the timing belt changed about 2 months ago. Could it be my IAC or my throttle body...what causes white smoke. ..not blue but white...PLEASE HELP
  2. Jun 21, 2015 at 5:29 PM
    ebayollis
    josh
    spruce pine nc
    I've been reading some more. ..how do you check for exhaust leaks in your radiator...just pop the cap, start it and look for bubbles?
  3. Jun 21, 2015 at 5:36 PM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    You mean a blown head gasket?
  4. Jun 21, 2015 at 5:37 PM
    ebayollis
    josh
    spruce pine nc
  5. Jun 21, 2015 at 5:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Blown head gasket. There is nothing more that explains the white smoke other then the fact the engine is allowing coolant into the combustion chamber. Even if you dont have bubbles.
    What it sounds like is happening is at dead cold the gasket is allowing leakage, but as it warms up it expands and allows a better seal. Which allows the engine to run normally.
  6. Jun 21, 2015 at 5:44 PM
    ebayollis
    josh
    spruce pine nc
    Damn...thats what I was afraid of
  7. Jun 21, 2015 at 5:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What gives it away is the white smoke and crap running. You could check for cylinder leakage, but at 209K your gaskets have seen better days. I would just get to pulling the heads if it was my truck. Get them resurfaced and presure tested just to make sure they are good to go and replace both gaskets.
  8. Jun 21, 2015 at 6:15 PM
    ebayollis
    josh
    spruce pine nc
    Is there any way to test to make sure
  9. Jun 21, 2015 at 7:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Bad head gasket, 100% for sure. Nothing else will cause white smoke.
    You can check the plugs to determine which cylinder bank has failed. Check the coolant level to see if it is low. If you pull the radiator cap and there is a vacuum in the system (air sucked in when you remove it) it is a very bad sign. See if you have oil floating on the surface of your coolant. See if there is white residue on the oil dip stick. Run a compression test on your cylinders.
  10. Jun 21, 2015 at 9:38 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The tests to make sure have already been confirmed. Start small and work your way up. Pull your dipstick and oil cap to see if the oil looks frothy. Then pull a plug and examine it. You can run a compression test (make sure you run it dynamically and not static as you get better readings rhat way and lastly you can run a cylinder leakage test, which will give you more then likely better information then the compression test. Anything past 20% cylinder leakage is bad. Under is normal. Many of your cylinders will read past 20 for sure and you will have low PSI on the compression test.
  11. Jun 22, 2015 at 1:29 PM
    ebayollis
    josh
    spruce pine nc
    One more qestion...do you have to remove the cams when taking off the heads or do they come out as an assembly with the heads and valvetrain?
  12. Jun 22, 2015 at 1:56 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    DOHC = Double OverHead Cam. The cams will come off with the heads.
