01 Tacoma Trailers Hook up
Discussion in '1st Gen. Tacomas (1995-2004)' started by RCYWR2001, Apr 5, 2016.
  1. Apr 5, 2016 at 3:29 PM
    RCYWR2001
    RCYWR2001 [OP] 1989 Mitsubishi Mighty Max 5spd
    Reuben
    01 TacoSR5 1989 MightyMax
    Cold air intake (done before purchase) and CAT delete. Max:Weber Carb
    Hello,
    I have an 01 Tacoma SR5 and I need to hook up a small trailer to it but I do not see any connection for the lights from the trailer.
    Am I missing something or is this something I need to add to my truck?
    I see different wiring kits online but I want to be sure before I go buy that I need it.
    Thanks!!!
  2. Apr 5, 2016 at 3:33 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Sometimes the wiring plug is attached to underside of bumper.
    RCYWR2001[OP] likes this.
  3. Apr 5, 2016 at 3:36 PM
    RCYWR2001
    Reuben
    I will look again when I get home.
    Thanks!!
  4. Apr 9, 2016 at 8:45 PM
    RCYWR2001
    Reuben
    I looked and it is blank. I see within coming from the front to my rear taillights but that is it.
    Koditten,
    Does your truck have a specific fuse for the trailer lights?
  5. Apr 10, 2016 at 5:09 AM
    koditten
    Kirk
    Central Michigan
    I'll have to check.
  6. Apr 10, 2016 at 6:22 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I had to wire my 04 for trailer lights, nothing was there.
  7. Apr 10, 2016 at 6:27 AM
    koditten
    Kirk
    Central Michigan
    IM thinking your truck doesn't have the plug.
    The easiest thing to do is drop off the truck at a U haul franchise. Those guys have all wire harnesses to wire up your truck.
  8. Apr 10, 2016 at 7:33 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Dont think any 1st gens came wired from factory?
    Edit: some came with hitch, 4 pin connector, and fan blades that draw more air.
  9. Apr 11, 2016 at 10:19 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    surprisingly i think there were a few rare ones. the more I read on here the more I see some came with the separate box in the cab that had the wiring setup (possibly dealer done?).
    @RCYWR2001 the easiest is to get a trailer wire harness like this:
    http://www.amazon.com/Hopkins-43315...1&keywords=2001+tacoma+trailer+wiring+harness
    easy enough to hook up if you can use a screwdriver and zip-ties :D
    RCYWR2001[OP] and Snowman like this.
  10. Apr 21, 2016 at 9:04 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Tekonsha #118379 T connector should be what you need. It goes to 4 wire trailer plug-included, easy connect set up.
  11. Apr 24, 2016 at 10:33 AM
    RCYWR2001
    Reuben
    UHAUL sounds like a great idea.
    I have looked at the wiring harness kits and my only issue is your running them off your taillights and now your running trailer and brake/signals off of the one fuse meant just for your truck. I am scared it won't carry that many volts
    Any ideas?
  12. Apr 24, 2016 at 10:41 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    I had the same kit, it was a Reese. Something quit working on it so I bought one from etrailer.com, works perfectly fine.
    RCYWR2001[QUOTED][OP] likes this.
  13. Apr 24, 2016 at 2:48 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I have that one from Amazon. Works great and was way cheaper than anything else.
    I wouldnt trust uHaul with changing wiper blades.
  14. Apr 24, 2016 at 5:49 PM
    veg hed
    veg hed Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    U-Haul wired up my 7 pin with trailer brake box and did a great job. 2 hours and done.
  15. Apr 24, 2016 at 6:24 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    There were trucks that came with the tow package, they even came with a higher amp alternator.
    And OP dont worry about the tail light circuit not being able to handle the extra draw. It'll be perfectly fine. Thousands of trucks out there running the aftermarket setup for trailer lights.
  16. Apr 25, 2016 at 1:10 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    For what it is worth these 4 wire trailer plugs with converter boxes over the years gave me nothing but grief .
    Every thing gets switched over to 7 conductor plugs
  17. Apr 25, 2016 at 5:11 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I run a 4-wire harness (to each tail light) and I cut the end off. then ran separate wires for the rest of the 7 pin functions. walla, custom 7-pin that i'll probably never use but it's there if I need it. I've had to replace the original one but that was due to age, it came off my grandfather's truck and was 8 years old. I have one that's rated for LEDs now and works good. Just make sure to seal the back of the housing so no water gets in, mine got corroded (can't succeed without failure right :) )
  18. Apr 25, 2016 at 3:36 PM
    MattFL
    MattFL Well-Known Member
    S. Florida
    1999 Tacoma V6 4x4 TRD Extended cab
    There is a plug-in adapter. You unplug the wire harness behind the drivers side rear tail light and plug in the adapter (access it from underneath the truck). The adapter then gives you a plug to plug in the trailer lights. My 99' came with one, there was a recall because they burned out (mine did) but I ended up buying my own replacement in the aftermarket before I knew about the recall. I think it was like $30 or something, and it has been in there for more than 10 years now and works great. That's the easiest way to go. Takes about 10-20 minutes to plug it in, then neatly run the wire down to your tow hitch and zip the wires to the frame.
