'01 tacoma vibrating at ~45mph
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lux, Jul 15, 2015.
  1. Jul 15, 2015 at 12:34 PM
    Lux
    Lux [OP] @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    I just recently got back from a 2 week vacation, and after taking the truck out i noticed that when i hit around 40-50mph something starts vibrating, its nothing overwhelming, but its noticeable, it seems to be coming from somewhere up front towards the front right. I'm usually in 4th gear when it happens, but even when i disengage the clutch it vibrates, same thing in neutral, I'm puzzled as to why it only happens at around 45mph? i know its not a transmissions problem because it would stop if i put it in neutral or push the clutch in right? and if its the motor it would happen at certain rpm's rather than speed right? so what could it be? my brother thinks its a wheel bearing or something in the right front wheel. it has been less noticeable lately, but it still happens more violently now and then. any ideas? thanks
  2. Jul 15, 2015 at 12:35 PM
    bongwhisperer
    bongwhisperer Well-Known Member
    horn that plays "la cuka racha,"
    Just take girls for a ride and drive 45. Problem solved.
  3. Jul 15, 2015 at 12:36 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Your tires settled and are now out of balance, get them rebalanced and rotated.
  4. Jul 15, 2015 at 12:44 PM
    tacomonster23
    tacomonster23 Well-Known Member
    06 Taco
    Yeah id start with a balance and rotate as well
  5. Jul 15, 2015 at 2:11 PM
    Lux
    James
    NJ
    2001 tacoma sr5 4x4
    ok, thanks, I'm getting new tires and wheels soon but ill rotate them and see if it helps
  6. Jul 15, 2015 at 3:15 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
  7. Jul 18, 2015 at 11:46 AM
    Lux
    James
    NJ
    2001 tacoma sr5 4x4
    just an update i rotated my tires and it is MUCH better, still does vibrate slightly especially when letting off the gas, but its 100x better, thanks. i have a feeling they do need to be balanced too but I'm getting tires soon anyway, i found 2 nails in my front right tire too, another reason for new tires
  8. Aug 4, 2015 at 5:06 PM
    Lux
    James
    NJ
    2001 tacoma sr5 4x4
    Update, I know this is kinda old, but found the time to get wheels balanced at STS, the guy took it for a test drive after I told him the problem, lifted it up, and turns out it's a bad universal joint, the one coming from the differential, there was a lot of play in it, they say it'll cost $220 to fix, so I just went with it, does that sound right? I'm not sure if it's a job I could've done myself or not, but I just wanted it fixed, should be done tomorrow, I'll let you know how it turns out, but they are saying I might need to do all of them after this one because they won't be able to see the play in the others until after this one? I don't trust that very much, if it is the case, I'll do it myself, $220 is enough for now
  9. Aug 4, 2015 at 6:13 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    40-60 bucks for the ujoint itself, 80 bucks/hr. 220 is pretty good. you could have done it yourself with a book. but only if you have the right tools and equipment. if you don't have the tools, then garage was the best choice.
  10. Aug 5, 2015 at 6:25 AM
    Lux
    James
    NJ
    2001 tacoma sr5 4x4
    What tools? Just curious, as long as nothing special is needed I probably could've done it myself, oh well, too late now.
  11. Aug 5, 2015 at 4:05 PM
    Lux
    James
    NJ
    2001 tacoma sr5 4x4
    Got the truck back, all fixed! no vibrating at all, even shifts smoother, nicely done too, I'm happy except for how much i paid, but overall solved the problem
  12. Aug 6, 2015 at 7:01 PM
    CodeSeven
    Serge.
    Coachella Valley
    ramp/stands/jack, creeper/something to lay on. ratchet/impact gun. set of metric sockets. needle nose, pliers, or dykes. hammer and a punch and/or chissel. grease gun and grease. wire wheel/brush to clean off any rust/grime. towels, pummice soap, degreaser. compressor and air ratchet/impact gun/air hammer. emery cloth.
