01997 Tacoma SX v6 5sp TVS1320 supercharged 300 HP! Haltech ECU, Reg Cab 800,000 Build
Discussion in '1st Gen. Builds (1995-2004)' started by 1997tacomav6, Mar 1, 2017.
  1. Mar 10, 2017 at 7:33 AM
    rj95lss
    rj95lss Well-Known Member
    Robert
    Pinelands, NJ
    '92 HZJ73 - 1HZ diesel RHD
    SOA with OME, Lockers, 37's, ARB
    Not sure yet - would love to test out a set of the reclining suspension baja seats!
  2. Apr 8, 2017 at 7:21 AM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    I resealed the whole motor, replaced all the timing belt and all the idler bearings and water pump, the strange noise the engine was making when you had it was a bad fan hub bearing, so replaced that and the knock sensors were acting up so I replaced them and the wiring harness, 31,000 miles later and a little more than a year later zero issues since the install, as you know she runs super strong from the test drive, thanks again,
    Black97v6MT likes this.
  3. Apr 9, 2017 at 8:54 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Good to hear! Weird that it didnt make that sound while i was driving it. But it sat a little while so that couldve caused it. Im glad its working out for you!! :hattip:
  4. Apr 12, 2017 at 3:29 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
  5. Apr 13, 2017 at 12:11 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Is there a place around Denver that has all of their seats?
    I really like your truck!!
  6. Apr 13, 2017 at 12:56 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    I think RSG has a bunch of swat options if I remember correctly. Also, they are the best Toyota off-road shop in Colorado, hands down
    1997tacomav6[OP] likes this.
  7. Apr 13, 2017 at 12:56 PM
    1997tacomav6
    Denver
    Thanks, RSG OFFROAD in Lakewood has 3 or 4 seats you can sit in,
    They sell them but they are 20 percent more than the website I think
    and wanted 200.00 to install them, only takes an hour to install and is super easy
    LG1, Baha, are there for sure.
  8. Apr 13, 2017 at 2:33 PM
    Wulf
    rock raisin
    Sweet, I'll have to check them out. Thanks for the tip!
  9. Apr 13, 2017 at 2:42 PM
    HeavyLifter
    HeavyLifter Well-Known Member
    Jeff
    Athens, Ohio
    2013 TRD Sport
    Outstanding!
  10. Apr 13, 2017 at 2:48 PM
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    Very impressive....great job keeping it going...
  11. Jun 12, 2017 at 2:58 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  12. Aug 14, 2017 at 6:13 AM
    tony2018
    tony2018 Well-Known Member
    What ecu are you running?
  13. Aug 14, 2017 at 6:14 AM
    1997tacomav6
    Denver
    Stock, I don't need anything else unless I wanted to add timing at 6000 feet,
    Snow performance methonal injection kit fixed all my issues and now I can run a 2" pulley without any issues
  14. Aug 14, 2017 at 6:18 AM
    tony2018
    Cool, was curious because in another thread about the supercharger you stated
    "When you tune the system it will spray at (5 pounds adjustable for me) and progressive it's way up."
  15. Aug 14, 2017 at 7:31 AM
    #35
    1997tacomav6
    Denver
    Correct, you do NOT tune the ECU, you tune the snow injection system, to determine the correct
    nozzle size, where your lean points are for when the system should start spraying adding 115 octane using a fuel air ratio gauge. Every setup will be a little different I would think depending on your altitude and engine, If you have a URD ECU kit system, piggyback then you can advance the timing and get additional power . The URD KIT does not address any of the heat issues created by the supercharger or adding a smaller pulley that creates even more heat whereas the methanol kit does address this problem without having to get An intercooler, methanol kit actually works better than an intercooler because there are no restrictions to airflow where an intercooler has air restrictions,
    Too much heat from higher boost levels will make the nose seal fail and burn the supercharger oil. Each pound of boost adds 10 degrees of heat to the supercharger,
    10 pounds of boost adds 100 degrees, so a methonal kit is very important if you want higher boost, an methonal injection kit can reduce temps by 100 degrees, win win situation
    tony2018[QUOTED] likes this.
  16. Aug 14, 2017 at 7:36 AM
    #36
    tony2018
    Thanks for the clarification on that. Good to know
  17. Aug 14, 2017 at 7:51 AM
    #37
    1997tacomav6
    Denver
  18. Aug 14, 2017 at 7:53 AM
    #38
    tony2018
    Watched it from the other thread, thanks.
  19. Aug 15, 2017 at 9:14 PM
    #39
    Oside7even6ixty
    Oside7even6ixty Well-Known Member
    How many miles with the water/meth kit? No issues with the bearings?
  20. Aug 16, 2017 at 4:07 AM
    #40
    1997tacomav6
    Denver
    About 2500 miles now, runs like a dream, the kit uses the smallest spray nozzle for my AFR needs and only sprays from 4.5 pounds of boost up, so the system is not on that much. I managed 1700 miles
    on my first gallon of boost juice, that's 6 tanks of gas for me. Every engine depending on altitude, boost, pulley and how you drive, etc will be a little different.
    Zero isues
