02 4banger Build
Discussion in '1st Gen. Builds (1995-2004)' started by JTaco25, Oct 5, 2016.
  1. Oct 5, 2016 at 10:03 PM
    JTaco25
    JTaco25 [OP] Active Member
    2002 2.7L 3rz-fe build
    Current Set up
    When i first bought her:
    Super clean with about 125 miles
    Specs:
    Engine/Drive Train:
    3RZ-FE 2.7L
    K&N cold air intake
    18" magna flow dumped before rear axle ----->
    B000COP65S.html
    Stock 4:30's
    Open F/R
    Armour:
    Trail Gear Low Profile Front Bumper with light hoop
    Tires/ Wheels:
    285/75 R16 Ko2's
    Daytona 16" Steelies
    Suspension:
    Front
    Bilstein 5100 (Lowest notch)
    OME 881's
    Camburg Uniballs
    Rear
    Bilstein 5100
    Stock Leafs with 2.5" block
    Random Mods:
    Smittybilt RTT with Custom Bed rack -----> B01LRJ64AC.html
    Viair 450C Compressor -----> B000FQ78VI.html
    CBI Ditch light brackets
    Blue Sea Fuse Block -----> B001P6FTHC.html
    Train Horns on separate Switch
    Uniden 520xl Ash Tray mod -----> B00004VXNI
    Custom Mount with Otrawtt Switches
    JVC Single din -----> B01N9KM2WR.html
    10" Alpine Sub
  2. Oct 5, 2016 at 10:31 PM
    JTaco25
    Got rid of the 20" wheels pretty quick
    275/70 r16s
    bigfella13 and Dalandser like this.
  3. Oct 5, 2016 at 10:49 PM
    JTaco25
    First trip out ended up getting stuck for 3 hours. Quickly realized these things only came with 1 tow point in the front and that was it.
  4. Oct 5, 2016 at 10:51 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Can you upload the first time you got your truck again. It's not showing on my screen.
    Dalandser likes this.
  5. Oct 5, 2016 at 10:57 PM
    JTaco25
    better?
    sorry new to this how do you actually tag someone in your msg for a reply?
  6. Oct 6, 2016 at 11:40 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Yes and you click on quote at the bottom right of the person you want and to reply back to.
    And I'm glad you changed out those wheels. Didn't look so good on the truck.
  7. Oct 6, 2016 at 11:42 AM
    JTaco25
    Thanks, and ya they were at bit much for me haha
    Have done a bunch since then just going to get some pictures
  8. Oct 6, 2016 at 11:44 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Not a problem and truck looks good! Keep up the build and welcome to TW
  9. Nov 27, 2016 at 8:35 PM
    JTaco25
    Ordered a pair of ditch light brackets from cbi and wired up some lights
    tacomatrd22 likes this.
  10. Nov 27, 2016 at 8:59 PM
    JTaco25
    Bilstein 5100's and OME 881's went in. Noticed the spindle was hitting the coils so i decided to bite the bullet and get some Camburg Uca's
  11. Dec 1, 2016 at 8:48 PM
    JTaco25
    She got a little face lift. Trailgear low profile with the add on light bar hoop.
    welded primed and painted
    Also moved my turn signals to side marker lights.
    Dalandser, tacomatrd22 and Camerond05 like this.
  12. Dec 3, 2016 at 6:53 PM
    JTaco25
    Installed an 18" magnaflow dumped before rear axle.
  13. Feb 7, 2017 at 7:33 PM
    JTaco25
    Dash setup.
    -Uniden 520xl ashtray mod
    -homemade switch bracket with otrattw switches.
    -Bluetooth Jvc single din
  14. Feb 23, 2017 at 6:28 AM
    SEAMONSTER401
    SEAMONSTER401 Well-Known Member
    Zach
    Mocksville, NC
    04 Tacoma 4x4 Ext Cab
    Hey man I have an 04 xtra cab 4 banger too. See you went with the 881s and billies. Is it a stiff ride with not a whole lotta extra front weight? Thinking of doing this setup also.
  15. Feb 23, 2017 at 9:19 PM
    JTaco25
    No man honestly not too bad. Maybe a bit stiff to start but now that they've settle I love them. I'm actually contemplating the 882's now though. Same spring rate I believe just a little more lift.
    SEAMONSTER401[QUOTED] likes this.
  16. Feb 26, 2017 at 6:30 PM
    JTaco25
    Bought this bed rack off a local guy. He built it for his old 1st gen. I should be ordering my rtt soon
  17. Feb 26, 2017 at 6:32 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Nice setup
  18. Feb 26, 2017 at 6:44 PM
    JTaco25
    Thank man. Just went through your build. I'm really digging the custom centre console set up you made. How hard were the subie seats to install?
  19. Feb 26, 2017 at 7:21 PM
    GreeGunc
    Jacob
    North GA
    Ah thanks man. The seats wasn't to hard, I just cut the mounts off the toyota seats and the Subie seats, then welded the toyota mounts onto the Subie seats. If I could do it again, id do it a bit different. They sit kinda tall and I'm almost touching the roof, but I'm around 6'4"
  20. Feb 26, 2017 at 10:03 PM
    MAUIAUSTIN
    MAUIAUSTIN Well-Known Member
    Austin
    Maui, Hawaii
    1995 Ext. Cab 4x4 SR5
    Sway A Way 2.5 Coilovers JBA Upper Control Arms Old Man Emu CS019R Leaf Springs Old Man Emu Stock Length Greasable Shackles 10" Travel Bilstein 5125 17" DX4 Terrain Wheels 265/70 R17 Falken Wildpeak AT3
    lookin great! what size tires are you running?
