02 5vz-fe manual idle issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by mjcari, Jun 28, 2017.
  1. Jun 28, 2017 at 5:07 AM
    mjcari
    mjcari [OP] Member
    Media, PA
    02 4x4 SR5
    My truck, new to me (after my 02 4 cylinder was totaled by a girl texting) has a strange idle.
    At cold start up (75 degree f this morning) it idles at 1600-1700. Once it warm up, it will settle down to 800-750. It seems to idle high when I am rolling to a stop with the clutch in also. Seems too high to me, but this is my first 3vz-fe, is it?
    I suspect one of the following
    1.) ect sensor? - no codes stored
    2.) vacuum leak - why not high all the time?
    3.) sticky IAC ?
    thoughts?
    I know some of you have experienced the same. Please let me know what you think.
    thanks.
  2. Jun 28, 2017 at 6:25 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I thought the 3vzfe was the old 90's camry engine?
  3. Jun 28, 2017 at 6:31 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You mean 3RZ
  4. Jun 28, 2017 at 6:32 AM
    mjcari
    mjcari [OP] Member
    Media, PA
    02 4x4 SR5
    edited title due to miss type. I meant the 5vz-fe - 3.4ltr v6
  5. Jun 28, 2017 at 6:34 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Those seem like normal idles to me. I don't have the v6 but still same idles cold/warm.
  6. Jun 28, 2017 at 6:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    x2
  7. Jun 28, 2017 at 7:12 AM
    mjcari
    mjcari [OP] Member
    Media, PA
    02 4x4 SR5
    That's what I wanted to know, is that normal. It seems high to me, as my 3rz didn't idle so high.
  8. Jun 28, 2017 at 7:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can try cleaning the IAC (if equipped) and see if the idle lowers. Also make sure you defrost is off.
  9. Jun 28, 2017 at 7:50 AM
    Madjik_Man
    Colorado Front Range
    Easiest steps would be to clean your MAF, throttle body and IAC.
    If you still idle high then you could have a bad throttle position sensor. But that usually throws a code.
    mjcari[OP] and 98tacoma27 like this.
