'02 DC with slight shimmy at 72.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacowaco, Sep 30, 2019.
  1. Sep 30, 2019 at 5:34 AM
    Tacowaco
    Tacowaco [OP] Well-Known Member
    Tallahassee, FL
    02 Tacoma Double Cab 4x4
    It drives straight and does not feel loose but at around 72 it gets a shimmy. I tried turning the wheel a little when this occurred to see if it was steering related but it had no effect. It has new tires and a recent carrier bearing replacement. I plan to get a wheel alignment and replace the rear engine mount. Any ideas would be appreciated!
  2. Sep 30, 2019 at 6:25 AM
    02hilux
    Planet: EARTH
    Make sure who ever replaced the CB correctly align the DS joint.
  3. Sep 30, 2019 at 9:26 AM
    Tacowaco
    Tallahassee, FL
    I used a white pencil to mark all the joints, it had a shimmy before the bearing. The old CB did not look that old and it was not OEM, so maybe whoever did that might have messed it up. I'll stick a cam under there and see if the DS is doing it.
