02 Double Cab Snugtop Supersport with Toyota bedliner?
Discussion in 'Tonneau Covers, Caps and Shells' started by Cincycaddy, Jun 6, 2016.
  1. Jun 6, 2016 at 5:45 PM
    Cincycaddy
    Cincycaddy [OP] Well-Known Member
    Picking up a used snugtop for our 02 Double Cab. Does the OEM Toyota bedliner need to be cut to accommodate the Snugtop? Snugtop comes with 4 universal clamps and not the original Snugtop ones if that makes a difference.
    Thanks,
  2. Apr 29, 2017 at 2:08 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Can't speak to Snugtop but for my Leer 100r, I removed the Toyota over the rail liner and swapped in a Toyota under the rail. No issues. if you have an over the rail, you might have to cut a few holes to accommodate the clamps.
    If you haven't already, might want to consider a suspension update. Once I had my leer on for a couple of weeks, I noticed a slight bit of sag in the rear. I'm looking at updating to Bilstein 5100's front and rear along with an AAL. I don't want anymore than a 1" lift but definitely want to eliminate that sag from the weight of the shell.
    Also think about adding a transmission cooler.
    Enjoy your snugtop!
