02 Engine Knock
Discussion in 'New Members' started by ButchL1947, Feb 12, 2012.
  1. Feb 12, 2012 at 3:56 PM
    ButchL1947
    ButchL1947 [OP] New Member
    Butch
    02 Tacoma SR5
    Just turned 116K and started hearing engine knock on cool mornings at low RPM's sound quickly ends upond short warm up - repair guy says "its a rod" and need to rebuild or replace engine - thoughts?
  2. Feb 12, 2012 at 8:15 PM
    undermoneyed
    undermoneyed aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Butch, it sounds like it could be your oil pump. Don't go for the rebuild yet. If your oil pump is failing, your oil pressure will be low on starting, therefore the knock. I'll usually hear a knock after I've changed the oil because it needs a second or two to get the oil moving through the engine and the pressure has to increase. Get your oil pump checked first. If it was a rod, it would continue after the warm up. My $0.02 worth. HTH.
    Mark
  3. Feb 12, 2012 at 8:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Drive it til it breaks. Maybe put a little engine honey in it.images_c024f04c305e2012eb767cc3f787a9e53831c5ac.jpg
  4. Feb 12, 2012 at 9:42 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
  5. Feb 14, 2012 at 1:30 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
