02 Leaf Springs Rubbing Exhaust
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoFiend7, Aug 2, 2023.
  1. Aug 2, 2023 at 2:32 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Thread Title: "Using Add-a-Leaf to Replace broken Leaf???"
  2. Aug 2, 2023 at 2:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :bananadead::bananadead::bananadead:
  3. Aug 2, 2023 at 2:40 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You're obviously right, how naive of me.
    Kwikvette[QUOTED] likes this.
  4. Aug 2, 2023 at 7:12 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    As pointed out, it is the longer shackles that are causing the problem, not the fact that your leaf springs are tired. In stock configuration, you should be able to compress the springs to the bump stops and have no spring to exhaust interference.
    When I went to OME Dakars I first used their exhaust relocation set up, I didn't like how low it hung the exhaust tip so ended up cutting it behind the axle. I used a pipe cutter.
  5. Aug 2, 2023 at 7:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No way, the obvious answer would be a water jet cutting tool
  6. Aug 2, 2023 at 8:22 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
