02 Pre Runner front hitch
Discussion in '1st Gen. Tacomas (1995-2004)' started by amp3d, May 15, 2017.
  1. May 15, 2017 at 6:36 AM
    amp3d
    amp3d [OP] Well-Known Member
    Mark
    Toronto
    2002 Double Cab TRD Offroad, 2012 Access Cab
    Hey Guys,
    A little while ago I purchased a CURT front mount 2" receiver for my Taco, and when I went to mount it the holes on the frame did not line up with the hitch. I ended up returning it.
    This is the hitch I got previously https://www.amazon.com/CURT-31013-F...54283&sr=8-1&keywords=2002+tacoma+front+hitch
    I'm about to try a different design hitch now (reese/draw-tite) listed here to see if it's any different. I hope this fits.
    I'm a little nervous though that maybe the pre-runners are different or something?
    For what it's worth, Toyota just did the frame replacement about 2 months ago lol, so now maybe the old one I returned may have fit? I have no idea!
    I can find installation instructions, but I cant seem to find any blueprrints or anything on these hitches so it's not easy for me to measure before purchasing. As you can imagine, returning these if they dont fit is a bit of a pain.
    Hoping someone has an idea for me :D
    Thanks!
  2. May 15, 2017 at 1:13 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    Usually on these hitches you have to remove the rear bumper and then slide the hitch in...in between the frame and bumper. So the hitch is sandwiched in the middle. Should have been the same on the curt as well. I used to install both brands a few years ago.
  3. May 15, 2017 at 1:24 PM
    amp3d
    Mark
    Toronto
    Sorry, this was a FRONT hitch I'm talking about, not the rear.
    I know how to install it, but the holes did not line up on the frame on the first hitch I got.
    The rear hitch is fine no issues I already put one of those on long time ago
  4. May 15, 2017 at 2:25 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what are you planning to use it for
    Might just be easier to have one built to your measurements
    How far were the holes off ??
    If you couldn`t even catch the M 12 welded nuts were the Tow hooks were??
    I wonder if you needed to trim the front of the frame off
    Like you do with most After market bumper installs
    It might be possible you got one boxed incorrect
