02 Prerunner Jumps after stops
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zwissbeats, Sep 28, 2011.
  1. Sep 28, 2011 at 6:43 PM
    Zwissbeats
    Zwissbeats [OP] New Member
    Todd
    Tallahassee
    '02 Prerunner SR5, 2wd, 6cyl
    small lift, bigger tires
    So my mechanic has driven my truck a couple times and it hasn't replicated the problem I am having. It is annoying and starting to be unsafe. I am looking for anyone who has had the problem before so I know where I can keep looking.
    When I come to a stop, traffic light, stop sign, what ever, my Taco jerks, jumps, lurches, forward. My mechanic wanted me to look at my tach to see if the rpms drop and the idle control over compensates. This is not the case. The truck idles at 750 rpms, just under 1000. It stays the same, then suddenly jumps, jerks, for a second then stops. I have tried checking my vacuum hoses, but have been unsuccessful finding any leaks. Obviously it isn't consistent, but i would say it happens 60% of the time. It sucks because it is enough of a jerk to make the truck go forward if i don't have the break pedal down enough to prevent it.
    Any ideas?
    Z
    ps- also if anyone has any tips on servicing the rear drum breaks, let me know, I am planning on doing it myself for the first time.
  2. Sep 28, 2011 at 8:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What you are describing sounds like axle wrap. This sort of thing is fairly common in 1st gens with the original rear leaf springs.
    If you are interested in finding out more about what folks here refer to as axle wrap, there has been a lot written about this topic. Here are some interesting threads, and a good place to start.
    http://www.tacomaworld.com/forum/1st...ml#post1900827
    http://www.tacomaworld.com/forum/1st...-wrap-mod.html
    http://www.tacomaworld.com/forum/1st...axle-wrap.html
  3. Sep 29, 2011 at 5:51 PM
    Zwissbeats
    Todd
    Tallahassee
    whippersnapper - i got the truck when it had 140k miles on it. i just had the tranny drained and filled with the filter cleaned out. Because i dont know if it had ever been flushed, we are sticking with draining and refilling.
    Thanks for the links to look up axel wrap...i will read up and see if thats it.
  4. Sep 29, 2011 at 5:59 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Does it feel like a little bump forward or is your truck like full on jerking, as if you had a manual trans and dropped the clutch with the breaks on?
  5. Sep 29, 2011 at 6:01 PM
    Warhorseforever
    Will
    Sand Lapper
    Also how are your leafs looking?
