02 Red Tacoma
Discussion in 'Audio & Video' started by Hillcountrychic, Jan 8, 2022.
  1. Jan 8, 2022 at 6:40 AM
    Hillcountrychic
    Hillcountrychic [OP] New Member
    Dolly
    2002 red Tacoma
    Lift
    Needing help my 02 Tacoma has 134,000 miles on it. I start hearing this rattling noise so I had the timing belt changed out with new water pump. The noise kept happening so I removed all the belts it kept doing it so I sprayed the timing belt belt with bead blaster lubricant an the noise stopped but it comes back after a couple hours of driving. I had clutch replaced too now seems to be a slight vibration an vacuum sound at 3,000 Rpms but goes away as soon as u pass 3,000 or go under it an this is with the vehicle in neutral sitting still. Maybe cheap oreilly clutch don’t know not sure if these problems are connected it seem to all start after the clutch job. I posted video of the timing belt noise. I sprayed the belt only. needing help this timing belt has about 800 miles on it.
  2. Jan 8, 2022 at 11:40 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You might not get much help in the Audio/Video forum
  3. Jan 8, 2022 at 4:11 PM
    Hillcountrychic
    Dolly
    2002 red Tacoma
    Lift
    Where would you suggest I post it? I tried uploading a video, but it won’t let me
  4. Jan 8, 2022 at 5:06 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    I’d post in the 1st gen forum. Owners of same gen would be better able to help you. I also believe you need 50 posts to add a link or pic.
