02 spark plug change
Discussion in '1st Gen. Tacomas (1995-2004)' started by cricket, Apr 3, 2009.
  1. Apr 3, 2009 at 9:32 AM
    cricket
    cricket [OP] New Member
    atlanta, ga
    02 tacoma base
    i'm looking to change the plugs on my base model taco. can anyone help me with this? looks like it might be a pain in the a. are they located under those pink colored clips? will i have to remove a bunch of stuff in order to change them? should i just get a pro to do it?
    thanks.
  2. Apr 3, 2009 at 10:28 AM
    Robbsolid
    Robbsolid Zombie Killer
    ABQ, N.M.
    02 PreRunner SuperWhite DBL Cab
    Plastic X'd Flares, deck plate mod, Thrush welded muffler, graphite painted wheels, relocated turn signals, fogs in bumper
  3. Apr 3, 2009 at 12:20 PM
    MurderedComa
    MurderedComa Well-Known Member
    California
    the link should help alot. I did mine without much automotive know how and came out just fine. Yes the sparkplugs are located under the coilpacks, mine weren't pink however.
  4. Apr 3, 2009 at 12:27 PM
    Robbsolid
    ABQ, N.M.
    i think maybe hes talking about the red sticker on the coil packs. Really, the 3.6l V6 is the easiest spark plug change I have ever done, just donnttttttt forget the anti seize, and checking the gap.
  5. Apr 3, 2009 at 12:40 PM
    tablesalt
    tablesalt Tacoma Lover
    Riverside, CA
    04 PreRunner, Double Cab TRD V6
    Good ole' Stock. Black.
    Do the plugs come pre-size for your truck, I mean, is the gap already set for your truck? Or do you always want to check the gap every time you buy plugs from the dealer or automotive places?
    Thanks.
    tablesalt
  6. Apr 3, 2009 at 12:58 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I dont think they come pre gaped. So I would go ahead and check them because its very easy and can save you alot of head aches.
  7. Apr 3, 2009 at 1:13 PM
    Robbsolid
    ABQ, N.M.
    I bought all NGK plugs, and they were not pregapped, its real easy to do it tho, it takes a few minutes for all of them
    I bought mine from autozone, make sure you get the part number you ask for, the guy at the counter was trying to sell me non-compatible plugs. There is a sticker on the timing belt cover that tells you which type of plug to use, and which on eto not use.
  8. Apr 3, 2009 at 1:34 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The 3.4L V6 5vz-fe uses the dual electrode plugs, use them and don't let the douche behind the counter tell you otherwise. If you don't use the dual electrode plugs your rig will run like crap.
  9. Apr 3, 2009 at 1:53 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    There is no such thing as pre gap. they might tell you they are pre gap but check them B4 you install them, 10 out of 10 times they are wrong.
  10. Apr 3, 2009 at 5:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. And be sure to gap BOTH sides on the dual electrode plug. :)
  11. Apr 4, 2009 at 9:51 AM
    tablesalt
    Riverside, CA
    Cool. Thanks. its good to know.
    tablesalt
