'02 taco 4x4 steering issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shabutie, Sep 17, 2013.
  1. Sep 17, 2013 at 2:58 PM
    Shabutie
    Shabutie [OP] Well-Known Member
    Zach
    Fort Stewart
    2002 Toyota Tacoma Limited 4WD 4dr
    Hey guys, before I bring it in I was wondering if anyone has advise. My steering is loose and making a worn out clunking sound when I go over bumps. Tie rods, ball joints and RIGHT steering rack busing all new/good. Any advice?
  2. Sep 17, 2013 at 3:00 PM
    Shabutie
    Zach
    Fort Stewart
    Note: my left bushing is unknown but I know you have to replace steering rack for that and I dont know how to tell if its messed up
  3. Sep 17, 2013 at 3:16 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    Actually you just order a set of polyurethane energy suspension bushings which replace all 3. Replacing one doesnt fix anything.
    Note: Im in the same boat and and im pretty sure the rack has had it period. They are not all that expensive to replace, you can get a refurb with lifetime warranty off ebay for like $250
  4. Sep 17, 2013 at 3:29 PM
    Shabutie
    Zach
    Fort Stewart
    Shows how much I know, I thought there was only two haha. Im crawling under it in a second. Thanks
  5. Sep 17, 2013 at 4:32 PM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
  6. Sep 17, 2013 at 4:39 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    do you still have your sway bar on? mine was clunking like crazy before I permanently removed it.
    I replaced my rack bushing w/ ES ones a couple months back and it tightened up the steering quite nicely.
  7. Sep 17, 2013 at 5:05 PM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Well im gonna get ES sway bar bushings soon, they look pretty bad. But my rack has a lot of play in it. Think i may weld the slip joint in the column up first and see what that does before i replace it.
  8. Sep 17, 2013 at 5:05 PM
    Shabutie
    Zach
    Fort Stewart
    Ill look at it. After some looking and research my other two bushings are shot, I work for Toyota and my mechanic said they can't replace driver side bushing without the entire steering rack, so I assumed I couldn't replace it but what he meant was Toyota doesn't make them without buying the whole rack but I can buy aftermarket ones for $30, so I'm buying them and doing it my self. If that's not the problem they needed to be replaced anyway.
  9. Sep 17, 2013 at 5:07 PM
    Shabutie
    Zach
    Fort Stewart
    Yeah, it's still on. I'm not intense wheeler, just camping/hunting trips so I'm keeping it lol.
  10. Sep 17, 2013 at 5:09 PM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Get the energy suspension bushings from wheelers for like $18. Its not a tough job, just a few standard tools and i think i used a C clamp and a socket.
  11. Sep 17, 2013 at 5:09 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    This. Check the sway bar bushings for looseness. Check the end links play or rough movement.
