02 taco 5 speed manual 4x4
Discussion in 'New Members' started by 02Artaco, Dec 31, 2019.
  1. Dec 31, 2019 at 12:21 PM
    #41
    eon_blue
    Azusa, CA
    Oh ok I thought you meant weld it when you said having it locked all the time...yeah I would always suggest a selectable locker over all others if you daily your truck or drive it to the trails. Lunchbox lockers are good too just gotta be mindful of them back there in certain conditions. But nothing beats having an on/off switch for the locker, whether it's air controlled or electronic.
  2. Dec 31, 2019 at 12:23 PM
    #42
    02Artaco
    02Artaco [OP] New Member
    Justin
    2002 tacoma 4x4 5spd manual 4x4
    so I just need to find same year model and pull actuator and bolt up n be done with it
  3. Dec 31, 2019 at 12:24 PM
    #43
    eon_blue
    Azusa, CA
    That would be the safe bet yeah, but maybe someone else could confirm if an 03 or 04 actuator would work as well
  4. Dec 31, 2019 at 12:26 PM
    #44
    02Artaco
    Justin
    ok I've heard alot about lunchbox lockers what are they exactly is it the same as a limited slip or is it the next step from limited slip
  5. Dec 31, 2019 at 12:28 PM
    #45
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm not 100% sure... @eon_blue probably knows better than me. But I think the ADD actuator is pretty much the same on 1st Gen Tacoma (96-04) and 3rd Gen 4runner (96-02)
  6. Dec 31, 2019 at 12:28 PM
    #46
    02Artaco
    Justin
    guys I prolly look like a rookie wheeler lol I've been around 4x4s and offloading my entire life but this is first time I've gotten into actually wanting to make my truck stouter and perform better offroad I want to do it all right tho I don't want to take shortcuts
  7. Dec 31, 2019 at 12:30 PM
    #47
    eon_blue
    Azusa, CA
    Limited slips are something different, limited slips supply partial power to each wheel for better traction..making them more ideal for street usage. Lockers supply equal power to both wheels giving you equal traction to both at all times while locked.
    Difference between a lunchbox locker and a selectable one is that a lunchbox automatically engages when the right amount of torque is applied. Under 'normal' driving conditions it will stay open. A selectable locker of course will only lock when you engage it via a switch.
  8. Dec 31, 2019 at 12:31 PM
    #48
    eon_blue
    Azusa, CA
  9. Dec 31, 2019 at 12:33 PM
    #49
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Yep... forgot about that.
    I'd look on 00-04 Tacos and 00-02 Runners... you'll know when you compare to your old one if it will work.
  10. Dec 31, 2019 at 12:34 PM
    #50
    02Artaco
    Justin
    so I'd be best to get electric lockers for front and back if I go that route
  11. Dec 31, 2019 at 12:36 PM
    #51
    02Artaco
    Justin
    can i take actuator off truck and still drive it or is that bad for truck
  12. Dec 31, 2019 at 12:36 PM
    #52
    eon_blue
    Azusa, CA
    IMO yeah. If you do get a lunchbox it's better to put it in the rear...like mentioned earlier CV axles are a lot weaker than solid axles and using a front locker can break a CV quick if you aren't careful with it. So having one that you can turn on/off up front is ideal on an IFS truck imo.
    There are people here that run auto lockers up front and swear by them so maybe they can chime in, I've only ever run a lunchbox in the rear on an older Tacoma.
  13. Dec 31, 2019 at 12:38 PM
    #53
    02Artaco
    Justin
    By the way guys thanks so much for all the help you guys are absolutely amazing and I've learned alot just from reading y'alls tips and helpful experience
    eon_blue likes this.
  14. Dec 31, 2019 at 12:40 PM
    #54
    02Artaco
    Justin
    where are the auto locker guys at lol y'all are welcome to chime in I like learning about these things
  15. Dec 31, 2019 at 12:42 PM
    #55
    eon_blue
    Azusa, CA
    honestly if you're new to offroading I would start with a rear locker first and go from there...I've never had a front locker and have only been in a handful of difficult situations where it would have been good to have. For the most part, 4wd will get you through most trails if you pick your lines wisely and have good tires/ground clearance/armor etc. If it doesn't, then there's a good chance a rear locker will be the difference and get you through.
    Front lockers are one of those things you eventually decide you need when you get to a point that the really hard trails you're doing are demanding it more often than not. And by hard trails, I mean some pretty damn hard trails. An experienced driver with 4wd and a rear locker will be able to get through most things.
  16. Dec 31, 2019 at 12:50 PM
    #56
    02Artaco
    Justin
  17. Dec 31, 2019 at 12:53 PM
    #57
    02Artaco
    Justin
    I am gonna just get a rear locker for now but since i daily drive my rig I'm trying to figure out best locker for a guy on a budget lol
  18. Dec 31, 2019 at 12:53 PM
    #58
    eon_blue
    Azusa, CA
    He's suggesting it for a front solid axle I think...mostly referring to Jeeps. Front lockers and solid axles are one thing but front lockers and IFS is another. I personally wouldn't even worry about doing a front locker now because most trails you won't find yourself needing it on. But this is just one opinion, I would take others' into account as well before deciding.
  19. Dec 31, 2019 at 12:55 PM
    #59
    02Artaco
    Justin
    @eon_blue for now I'm gonna fix my clutch get my 4x4 back going and eventually get me a rear locker just want to figure out best locker for my money for rear
    eon_blue[QUOTED] likes this.
  20. Dec 31, 2019 at 1:53 PM
    #60
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
