02 Tacoma - brake light indicator problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02 Taco, Jun 23, 2008.
  1. Jun 23, 2008 at 10:18 AM
    02 Taco
    02 Taco [OP] New Member
    02 Pre-Runner Xtra-cab V6 2WD
    K&N OEM replacement air filter
    Hi there -
    I'm new to the site and this is my first post. Need help with brake light indicator. When releasing the parking brake, the light in the instrument cluster remains on. I've checked the brake fluid under the hood, and everything looks fine. Any recommendations?
    Thanks
  2. Jun 23, 2008 at 2:15 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Welcome to TW.
    Your parking brake is mechanical. The brake fluid has nothing to do with it. Check the tension on the cable under the truck. It's adjustable. You may want to lube the cable. The bell cranks may be frozen. Or, the rear brakes may just need adjusted. There are a number of possibillities Before you try any of this, try jiggling the handle a little bit first.
  3. Jun 23, 2008 at 3:11 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    IIRC, there's a sensor right behind the handle when the e-brake is off. It should be on the other side of the handle.
  4. Jun 23, 2008 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The brake fluid sensor is very sensitive. Fill the fluid up to the max level, and see if that does it. :)
  5. Jun 23, 2008 at 6:40 PM
    ShrockTaco
    ShrockTaco Unemployed
    Houston, Texas
    02 4Runner (Current) 99 Tacoma 4x4 5spd (Sold)
    Shrockworks Front/Rear Bumpers.
    common problem, start truck> take parking brake off > wait till light stays on > then push the parking brake farther IN if light goes off when pushed in then its the switch on the floor, release brake if light comes back on its definately the switch.. I never got rid of the problem so i just taped the switch in a close loop (taped the button down) and no more annoying light..
  6. Jun 27, 2008 at 11:47 AM
    02 Taco
    thanks for the advice, but I think I'm still at a loss/ confused. Here's what I found out via the 02 factory service manual:
    1. The "Body Electrical - Troubleshooting" section explains that a problem with the brake warning light can be linked to "suspected areas" such as the brake fluid level warning switch, parking brake switch and/ or meter circuit.
    Now I don't have an OBD scanning tool and don't have a good/ trustworthy mechanic. Taking my truck to the dealer is last resort, because I'd rather not be swindled out of a couple hundred dollars for a cheap DIY fix.
    Any workarounds or step-by-step help is greatly appreciated. Besides the brake light being annoying, I'm concerned that this issue with the "switch" (or whatever) may lead to other problems, etc. and pose a risk.
    Thanks
  7. Jul 8, 2008 at 1:08 PM
    Slow
    Slow Well-Known Member
    SoCal
    04 SR5 TRD
    having same issue on 2004 Taco...parking brake light stays on!!! Underside looks good and switch is being depressed. Will check fluid today. Anyone ehave fix????:confused:
  8. Jul 8, 2008 at 5:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Top your fluid to the "full" line. It should go off. :)
  9. Feb 9, 2016 at 4:28 PM
    03tacoma4x4
    03tacoma4x4 Well-Known Member
    Western NC
    2002 Silver Tacoma TRD V6 4x4
    2016 Tacoma Wheels
    Not sure how to fix it but on the bar that the handle is connected to is a little piece of metal that pushes a switch in when the parking brake is released. This is where your problem lies
