02 Tacoma door lock problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by ExtremeRider, Feb 2, 2015.
  1. Feb 2, 2015 at 1:40 PM
    ExtremeRider
    ExtremeRider [OP] Well-Known Member
    Friend of mind has 02 Tacoma and his driver’s door lock has been giving him some problems. Does anyone know if driver’s and passenger’s locks are interchangeable? He is considering switching them if they are the same. Thanks in advance.
  2. Feb 2, 2015 at 2:42 PM
    Kchapp
    Kchapp Active Member
    Kevin
    Birmingham
    02 Double Cab SB
    General Grabber At2 on Helo He791 wheels, LED interior dome and map lights , Opt7 Led headlights, Pioneer In dash DVD, Parking brake bypass for DVD, Husky liners, Drop in UTR liner, Stainless D Cab toolbox, K&N air filter, Westin nerf bars, Mounted aux/usb input from head unit. Bluetooth OBDII module.
    Are talking about the lock assembly inside the door that latches around the striker? If so, the answer is no. They're right opposite of each other.
  3. Feb 2, 2015 at 3:19 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    First, spray some lubricant in it, Tri-Flow is recommended.
    If that doesn't help, have a locksmith cut you a new key. Your key and cylinder may have worn down a bit, rounding over the edges on both and it's not lifting the wafers like it should. A new key, even cut from an old key, will have sharper edges and may solve the problem. I'm not talking about the peaks and valleys in the key, but rather the actual edge of the key. The cuts should be flat, not rounded over.
    Like was mentioned, the cylinders are handed and not interchangeable.
    If you carry a lot of extra weight on your key ring (extra keys, Hello Kitty key ring head, etc...) it will wear out the key and ignition cylinder quite fast and cause problems with the other cylinders.
  4. Feb 2, 2015 at 6:49 PM
    ExtremeRider
    Thank you guys for the info, we will try that!
